1990 civic Zc issues. please help
Old Jul 8, 2013 | 12:54 AM
EF'nStanced21's Avatar
Default 1990 civic Zc issues. please help
OK so I've had my car for a while and still can't get it to run properly. Im going to list all of what I have done so far and any suggestions as to what to do next would be greatly appreciated.
Replaced head gasket
Replaced intake manifold gasket
New distributor
New plugs and wires
New o2 sensor
New fuel filter
All my injectors seem to be getting fuel
I cleaned my iacv
New map sensor
The problem is every time I start the car, my idle is kind of choppy and if I give it gas, the car bogs like it wants to die and it kind of sounds like air is being sucked up quickly but then you give it more gas it goes away.
Sorry if its a little confusing, that's the best way I can describe it lol.
Thank you in advance.
Old Jul 8, 2013 | 01:53 AM
b16lewis's Avatar
Default Re: 1990 civic Zc issues. please help
check the timing
LudeEFv2.4's Avatar
My old title sucked.
What ecu are you running?
Old Jul 8, 2013 | 01:54 AM
LudeEFv2.4's Avatar
Originally Posted by b16lewis
check the timing
Good call.
Also make sure your firing order is correct.
Old Jul 8, 2013 | 02:24 AM
Alright I'll check tomorrow
Thanks
Old Jul 8, 2013 | 07:06 AM
jonGSR's Avatar
Possible fuel pump is bad.
Old Jul 8, 2013 | 12:31 PM
Yeah my friends told me he thinks its the fuel pump as well. so I might replace that as well just to be sure.
Old Jul 8, 2013 | 04:06 PM
mike205's Avatar
If you still have a catalytic convertor it might be clogged
crave13k
Sep 2, 2011 11:33 PM
1SlowSiHB
Dec 21, 2009 04:47 AM
pchris52
Apr 17, 2006 04:00 PM
Xander teh Grate!
Jan 14, 2006 03:02 PM
therealciviczc
Sep 4, 2004 03:41 PM
