96 ex b16 questions
Hello all, I have a couple questions for you.
Car/Motor: 96 civic ex 2 door/b16a
1. The motor is stamped b16a so that is a jdm block. the head has (0l0) (xl2) (2l1) (0l6) the x is blank. pr3-3. Is this a 99-00 si head or could this be a 2000 civic vti b16?
2. Is the usdm/jdm b16 water neck in different locations like the usdm and jdm b18c?
3. What o2 sensors can I use? I looked up 96 ex and 00 si and they have different part numbers.
Any help is greatly appreciated.
1) It is a 2000 year cylinder head. Beyond that, I couldn't tell you much about it without looking inside of it.
2) Should be the same, IIRC. Someone correct me if I'm wrong here...
3) Use the o2 sensors for a 99-00 Civic Si (Upstream #13539 / Downstream #13363 - BOSCH numbers)
pinoyboy204
Jul 24, 2006 10:55 AM
bmxmarine
36
Nov 12, 2004 09:00 AM
