fast blink signal
Old Jul 7, 2013 | 12:46 PM
greeen ranger's Avatar
Default fast blink signal
my right front turning signal does not come on. when i turn my hazard lights on all of them flash except the right front. i already changed the turn signal bulb only thing i have left to go to is the turn signal fuse/relay? i dont know where it's at specifically but does anybody have a diagram of where its located?
Old Jul 7, 2013 | 12:50 PM
grumblemarc's Avatar
The Grumpiest
Default Re: fast blink signal
I'm more than 1000% it would be located one of two places. Have you tried Googling for an image? A field service manual will also be something to invest in for just this kind of question.
Old Jul 7, 2013 | 12:54 PM
B_Swapped93's Avatar
could be the plug or the wire is bare from corrosion have a look.
Old Jul 7, 2013 | 01:33 PM
Former User's Avatar
Neither of these^ is the problem.
Test whether the right front bulb receptacle gets voltage and ground.
Old Jul 7, 2013 | 01:37 PM
EJDom's Avatar
10 Year Member
Test whether the bulb right front receptacle gets voltage and ground.
This.
Old Jul 8, 2013 | 12:20 AM
wheelerboy12's Avatar
A multi meter would come in handy, My friend had the same issue on his truck, he had no idea what was going on, replaced all the bulbs, fuses and such and nothing, went with a multi meter and found the bulb socket wasnt getting power, traced it down to a pinched wire.
Definitely get a multi meter and start poking around.
lien
24
Nov 30, 2021 04:10 PM
superfly23
Honda CR-V & Element
Feb 22, 2016 01:00 PM
fthesys
May 4, 2006 08:07 PM
Electrodynamic
Mar 1, 2005 04:24 PM
