B20 swap questions
I am swapping a b20 in my 91 wagon. The questions I have are:
1. Which rear engine bracker do I exactly need. I am using Hasport mounts for ef chassis with cable tranny. Will the bracket that I took of the b16a fit?
It mounts of to the rear mount on the subframe, but I do not see where it would bolt onto the b20 though.
Or is the #11 bracket in the link the only one that will work. Looks different from the picture. http://www.acuraoemparts.com/delray/...All&vinsrch=no
2. The side bracket by the timing belt cover. When I put my hasport mount on this is is no vertical to the engine. Which bracket will I need for this mount to line up properly?
2. Can I just use the Intake manifold off the b20b. It is not the giraffe looking one. As well as the throttle body and cable?
It mounts of to the rear mount on the subframe, but I do not see where it would bolt onto the b20 though.Or is the #11 bracket in the link the only one that will work. Looks different from the picture. http://www.acuraoemparts.com/delray/...All&vinsrch=no
What about the intake manifold is the b20b manifold fine to use if it is the low cut one. Or how much power difference is there if I also put on a DA manifold.
What headers will bolt up to a b20b Only the DA headers, and downpipe?
Also does it matter which engine the da has. Because they came with a b16a/b17a/b18a. http://en.wikipedia.org/wiki/Honda_I...DA9.2C_DB1-DB2. I would assume I would have to find a DA with a b18a. Because the B18 and B20 are pretty much the same engine.
