Just mpfi, or more...
Old Jul 6, 2013 | 07:37 PM
muth-33's Avatar
Default Just mpfi, or more...
I want to build my 91 civic cx just not sure what rout to take. Should I just do a mpfi swap or drop in a b18 or something else right away. I have a buddy who had a b18 in his and he liked it alot. I also would like to replace alot of the trim/ moldings and clean it up alot, but not sure where I can find it at. Any input/ ideas?
Old Jul 6, 2013 | 09:51 PM
89ED's Avatar
Default Re: Just mpfi, or more...
make it front wheel drive and weld the diff with a f22a6 with a b16 head and a k20 trans
Old Jul 6, 2013 | 10:00 PM
turn&burn89's Avatar
seems like a long route if you're thinking of mpfi. im in the same boat as you with the swap...i have everything for the MP but it seems a waste of time if i source an engine and everything. if you have the money for the b series id do that. its a substantial increase in power over a stock ''b7.''
Old Jul 7, 2013 | 06:28 AM
muth-33's Avatar
That's what I was thinking also, how hard is it to drop in a VTEC b16? You can pick the entire moter up for around a grand maybe a bit more.
Old Jul 7, 2013 | 07:37 AM
pretty easy if you have the hoist and all the tools. ive seen some people put a dent in the wheel well so the alternator will fit. you need motor mounts but i heard you can use the driver side off a 95 del sol dohc. plus tranny and axles and misc. parts. thats cheap dude, good for you!
Old Jul 7, 2013 | 08:40 AM
24TEN's Avatar
PHANTOM MENACE
If your car is DPFI as it sits right now then any swap will REQUIRE you convert it to MPFI.
Old Jul 7, 2013 | 10:41 AM
muth-33's Avatar
I understand I gotta do mpfi swap no matter what. I was just wondering if I should do all that work if I'm going to swap in a new motor anyway, or if I should just do mpfi swap and leave it as is.
Old Jul 7, 2013 | 12:08 PM
24TEN's Avatar
PHANTOM MENACE
Gotcha. Personally I'd do it on your stock motor because you know it's mechanically sound. The flip side is if your plan is to swap eventually then the parts specific to the d series will be sort of a waste.
I guess I've just had a few bad experiences with used engines.
Old Jul 7, 2013 | 12:37 PM
muth-33's Avatar
I know my current d series motor is in good shape, got the car from a very meticulous ex Honda mechanic, I guess I should say I trust the guy. I don't need massive amounts of power. What can I expect to get out of a d series motor? And is there any reason for keeping a d series instead of swapping?
RickyDayz
16
Mar 12, 2015 11:32 AM
gheinrich
Honda Civic (2006 - 2015)
Mar 19, 2014 10:04 PM
brandon2000
20
Dec 4, 2008 08:45 PM
meatdentist
Nov 14, 2005 11:06 PM
fOmaNPu
12
Jun 24, 2002 06:20 PM
