timing at 30'?? mpg
Old Jul 6, 2013 | 02:35 PM
jz2518's Avatar
Default timing at 30'?? mpg
i just replace the timing belt. the car runs runs and idles great. I set the timing at 16' with a timing light with the jumpers. the car gets bad mpg. But when i advance the dizzy to aorund 30' degress the rpm pick up and it sounds smoother. Is that normal? i Dont have no cel codes.
Old Jul 6, 2013 | 02:46 PM
Former User's Avatar
Default Re: timing at 30'?? mpg
Set the ignition timing to spec and do a complete ignition system tune up.
Does the CEL work?
Old Jul 7, 2013 | 08:18 AM
jz2518's Avatar
yes the cel works. i was getting a ECT - water temperature sensor code. I replace the sensor. and cleared the codes.
Old Jul 8, 2013 | 07:09 AM
kyden's Avatar
it's not possible to get 30 degrees base timing.
MastaFlyMason
Oct 2, 2016 06:47 AM
deezknuts
14
May 13, 2014 01:41 PM
.BigSexy
Oct 19, 2006 05:07 PM
TMTNG9
Aug 14, 2005 05:21 PM
AndyD
Aug 4, 2005 06:40 PM
