Overheating Mystery???
First post ... I've been coming here for a while but usually am able to find the answers to my problem by following other people's posts. This time I'm coming up blank. I've found similar topics but none with my particular issue... so here it goes.
The car is a 96 Civic LX. I've been having some temperature problems with it for a while. The scenario is usually the car doing well for example on a 40 mile trip to work... no temperature spike, reaches destination fine. I might park it the whole day (or drive it back inmediately) and then maybe halfway back the temperature starts to rise... never to a point of reaching top temp and staying there, it rises then on it's own levels down... then rises again then back down and so on until I get home.
On one of those episodes the Mrs was the one driving and the radiator plastic top cracked... she didn't notice, ended up blowing the head gasket. I had the radiator and engine fixed, hoping maybe that would take care of the problem... it didn't. Continues the exact same way and it's driving me crazy. On some longer trips I've noticed that for example when the car is climbing a hill temp starts rising... as soon as I'm over the hill it starts going back down. Not sure if it's the inclination factor or the engine working harder when going uphill.
What has been done or tested:
-replacing the cap
-replacing the thermostat
-removed the thermostat
-repairing and cleaning the original radiator
-replacing the radiator
-tested the engine for leaks with pressure
-always on fan (in case it was the fan not coming on when it should)
My next shot was trying a 1.3 lbs cap to see if maybe the 1.1 it currently has is not up to the task.
So there it is... any suggestion or any Civic wizard out there that can point out anything else I'm missing I'd greatly appreciate it.
Thanks
-replacing the cap
Thanks
Raise front of vehicle, turn heat on in car, remove radiator cap, start engine. Fill as necessary. Wait until the lower hose gets hot nor the fans cycle on/off twice, meaning the Tstat is open. Reinstall the OEM thermostat...meaning the one you bought from a Honda dealership, anything else is asking for trouble
What leads me to believe that's not the problem is that the temp issue is exactly the same before and after all that happened.... as if the problem was somewhere else.
right but i was leaning towards was overheated prior to your owning. does it ever loose coolant? alao you said you did. pressure test to system was it done warm or cold? as i have seen little tiny leaks (that cause overheating) that would only be found when car was hot/warm.
I don't thing that the problem comes from before I got the car because I've had it for about 4 years.... and the problem goes back to about 2 years... I was able to make very long trips before without any heating problems whatsoever.
It doesn't loose too much coolant in the radiator... but it does in the reservoir...
well you deff have a leak then. it is a closed system and should not loose any. my guess is your loosing just enough to make temp go up because coolant can not cool off "enough"
cbr_ryder
Classic Hondas
16
Jul 28, 2023 07:13 AM
cbr_ryder
Classic Hondas
Jan 6, 2022 05:47 PM
Jwbetley
Oct 12, 2008 01:18 PM
