Oil Pan Gasket Issue
Old Jul 4, 2013 | 05:13 PM
spok's Avatar
Default Oil Pan Gasket Issue
What would cause an oil pan gasket to blow out like this?
Old Jul 4, 2013 | 05:43 PM
grumblemarc's Avatar
The Grumpiest
Default Re: Oil Pan Gasket Issue
Torqued down too much.
Old Jul 4, 2013 | 05:54 PM
B_Swapped93's Avatar
i'm guessing you DID'T use a torque wrench. it's not a lot even something like 16lb or less iirc.
Old Jul 4, 2013 | 06:07 PM
spok's Avatar
I didn't do it, I took it to Precision Tune auto to change the gasket. I noticed after a week that it was still leaking so I took it back to show them what happened, and they told me something was wrong with my engine oil pressure, that it was too high and that's what made it blow out like that.
Old Jul 4, 2013 | 06:10 PM
spok's Avatar
I searched for an answer to this, and some people said it could be a bad PCV valve, or an issue with air intake. I have a cold air intake installed:
Could that be it?
Old Jul 4, 2013 | 06:16 PM
The Grumpiest
That would be the first time I have ever heard of that. I would say it's doubtful.
Old Jul 4, 2013 | 06:25 PM
un likely...they messed up is more likely. it's not hard to "DIY" search on her and you should find out how in a short time. simple by most standreds
Old Jul 4, 2013 | 07:56 PM
instrument's Avatar
Fyi. Your engine bay is ashy as hell.
Old Jul 4, 2013 | 08:11 PM
Buckshot870's Avatar
This exactly
Old Jul 4, 2013 | 08:12 PM
Could that be it?
Off topic, sorry, but when is the last time you cleaned/changed your air filter? Your engine bay is quite dusty
jbpnoman's Avatar
Yeah no, an intake isn't going to cause that. Spok, the way your intake is installed, it isn't a CAI. Either it's installed wrong, or it's the wrong intake for the car.
That gasket wasn't installed correctly.
Old Jul 4, 2013 | 09:00 PM
mikekh10a's Avatar
haha, on a serious note though...
it seems like precision auto screwed up big time on your car.
Old Jul 4, 2013 | 10:44 PM
axis11's Avatar
Too much gasket maker used. You are supposed to put just a little on the corners.
You will have the oil pan gasket oozing out before you reach specified torque. The rubber gasket tend to slide due to the slippery liquid gasket. Did you use any form of cleaner (carb cleaner, gasoline, etc)?
94 IntegraLS
May 7, 2013 11:42 AM
My_EFsedan
Apr 2, 2009 11:43 AM
miro_gt
Jun 24, 2007 08:02 AM
teler86
14
May 18, 2006 05:18 AM
yellowbulbs
Jul 17, 2001 01:12 PM
