(HELP) B16a block and head with 82mm pctx pistons.
Old Jul 4, 2013 | 02:31 AM
phferreira1's Avatar
Default (HELP) B16a block and head with 82mm pctx pistons.
Someone here already used the nippon piston 82mm pctX in B16A?? I need help on my block the piston is passing almost 1mm height of the block. What can be done? Anyone ever had this problem?
Old Jul 4, 2013 | 02:37 AM
jbpnoman's Avatar
Default Re: (HELP) B16a block and head with 82mm pctx pistons.
PCTX are CTR pistons. The CTR uses the B16B, which has a taller deck height. You aren't going to make those work without some creative fabrication. Sell them, and get the correct pistons.
This is also something you could have found out with 5 minutes of searching.
Old Jul 4, 2013 | 04:09 AM
But I find piston 82mm pr3? I just find forged a high price.
Old Jul 4, 2013 | 04:23 AM
doublezerohatch's Avatar
Pistons that don't work for your application are also very expensive . . . now u gotta sell these . . . probably wont get what u paid for it all . . and then you gotta buy the right stuff . . all that installation and removal . . . Whats your time worth? 5 minuites of research sure could of saved you a few weeks of trouble . .
Old Jul 4, 2013 | 04:45 AM
grumblemarc's Avatar
The Grumpiest
You need to stop reposting this same issue when you've already been told.
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/b16-block-nippon-82mm-pct-pistons-3154900/
Originally Posted by phferreira1
Okay, I read the other forum, my only option would be thicker HG. I believe still gain compression, will use ethanol, then hopefully everything right. I thank those who tried to help.
I'll take the test if not work out I buy another.
What happened?
Old Jul 4, 2013 | 09:52 AM
Ok, looks like I found 82mm P30 piston on ebay, however I wanted to find a way to use PCTX, so to see what is going. Thought until the piston in machining and demote a little "edge"..... you guys might find something crazy but I'm about to take the test, even if I buy P30. grumblemarc, you think that's crazy??
phferreira1
16
Jun 28, 2013 07:35 PM
91teg
64
Aug 22, 2011 03:34 PM
iKhmaiFoSho
Apr 26, 2006 07:36 PM
Mar_DC2
May 17, 2003 08:28 PM
