d16a6 manifold help!!
Old Jul 3, 2013 | 07:58 PM
Z0831xiz's Avatar
Default d16a6 manifold help!!
First off in advance thanks everyone for posting and reading. Spreading the Ef-love
Okay so my ef si has its stock mpfi obd0 manifold.
But it has a few problems. One of my studs are broken the one closest to cylinder #4 .
any idea how I could fix or replace that?
Now second.My engine intake manifold has a aftermarket fuel rail. The lining inside where the injectors go into are stripped also on the one closest to cylinder #4. I replace the injectors it had to d16a6 injectors as it had d15b7. But does anyone know a fuel rail I could use rather than ad16a6 fuel rail as I've gone to junkyards and I can't find a crx si or ef si or ef ex . Most are DPFI .
So which one would be a good aftermarket fuel rail or OEM fuel rail I could use retro fitted ?
Thanks for your help everyone much appreciated!
Old Jul 3, 2013 | 08:01 PM
F22Master's Avatar
Default Re: d16a6 manifold help!!
For the broken stud: google broken stud removal. Then just install a new stud.
Old Jul 3, 2013 | 08:08 PM
EFnCRX's Avatar
If you have some stud left tighten a vice grips as hard as you can and snap it on the stud as tight as possible and spin off.
If the stud is broken off almost clean with the flange you can take a nut slightly larger than the stud and hold the nut with a vice grips and fill the nut with weld.
Then remove the nut and the broken stud should come out if your weld was sufficient.
Also your weld wont stick to the aluminum intake manifold but be sure to cover your windshield glass as well as anything flammable with a welding blanket or equivalent. Hope this helps man!
Shoot me a pm if you cant find a fuel rail as I should have a few in my garage!
Old Jul 3, 2013 | 08:09 PM
Z0831xiz's Avatar
okay thanks f22mast . I'm sure there are lots of questions on this and replacing them them!
Posted from Honda-tech.com App for Android
Old Jul 3, 2013 | 08:21 PM
Z0831xiz's Avatar
okay sounds good Efcrx .
so basicly bend the stud that's left and twist off ? I has some stud left. how do I put a new stud in do I use a pressure plate to put in (same as you would do with the rear trailing arm bushing?)
Old Jul 4, 2013 | 05:53 AM
jlicrx's Avatar
the studs just screw in and out of the head - to get the broken one out, use the vise grips and screw it out - to put the new one in, double nut the stud and screw it in
Old Jul 4, 2013 | 08:53 AM
Z0831xiz's Avatar
okay sounds great thanks J and the stud is on my manifold. but I'll go to my local vatozone and get a stud. idea on the fuel rail a OEM one I can use besides a a6 one or would some how a b2 one work even if its dpfi
Old Jul 4, 2013 | 09:29 AM
F22Master's Avatar
D15B2 doesnt have a fuel rail. Both injectors plug straight into the TB/Intake manifold. Almost any D Series fuel rail should work. Google 'd series fuel rail interchangeability' or something like that.
Also, you could find studs at any Ace Hardware. M8x1.25mm ~40mm long.
Old Jul 4, 2013 | 10:57 AM
EFnCRX's Avatar
Thanks J for helping describe my post lol!
Make sure to buy a quality stud since this sucks the second time around also
jon570
Mar 7, 2019 07:01 AM
AzntaggeR
Apr 3, 2004 07:30 PM
zCivic
Feb 22, 2004 06:23 PM
YumVTEC
Mar 25, 2003 07:18 AM
