Questions
Old Jul 3, 2013 | 05:44 AM
D16honda2's Avatar
Default Questions
hey, I have a 1999 civic EX and im thinking about changing them cause I was tightening my exhast and I noticed the mounts were bad, so might as well replace the whole thing right? I don't know the size I need, I looked around online and some were saying 22mm? is that right? any brands recommended?
Old Jul 3, 2013 | 05:45 AM
D16honda2's Avatar
Default Re: Questions
sway bars.... wow sorry
Old Jul 3, 2013 | 05:53 AM
grumblemarc's Avatar
The Grumpiest
Leave it stock. Swap whatever bad bushings out that you find.
Old Jul 3, 2013 | 05:56 AM
JuggerNaut-CTR's Avatar
Why replace the entire bar and everything else when the bar doesnt go bad....its the bushings.
The bushings will say what mm they are most of the time on the side... Or you can measure the diameter of the bar with a caliper
Old Jul 3, 2013 | 06:09 AM
D16honda2's Avatar
well if im going to change the it anyways I might as well do it while im changing the bushings, instead of making a second trip down there. and then changing it or is it better to just leave the ones it came with in it?
Old Jul 3, 2013 | 06:12 AM
doood's Avatar
been there done that
dont go messing with things like sway bars when you don't know what affect different sizes will have on your handling
Old Jul 3, 2013 | 06:13 AM
D16honda2's Avatar
so change the bushings and leave it alone?
Old Jul 3, 2013 | 06:14 AM
sleepyaccord96's Avatar
replacing the sway bar itself make NO sense unless you are upgrading to a BIGGER diameter bar.
It sounds like you are describing bad bushings and that means you need to replace the sway bar BUSHINGs, not the bar...replacing the bar is more work and it makes absolutely no sense unless it is bent or damaged in some way.
Old Jul 3, 2013 | 06:16 AM
The Grumpiest
I think I said that almost verbatim.
here is what you need
http://www.ebay.com/itm/MOOG-K90565-Sway-Bar-Bushing-/171069219003?pt=Motors_Car_Truck_Parts_Accessories&hash=item27d48520bb&vxp=mtr
^^ you need one of these, it does BOTH sides of the car
might as well replace the sway bar END LINKS while your doing work under the car.
http://www.ebay.com/itm/MOOG-K90123-Sway-Bar-Link-Kit-/350746515547?pt=Motors_Car_Truck_Parts_Accessories&hash=item51aa1f185b&vxp=mtr^^ need to get "2" of these..one per side of the car
Old Jul 3, 2013 | 06:17 AM
D16honda2's Avatar
alright Thanks
96romaEK
Suspension & Brakes
26
Apr 16, 2010 03:25 PM
H22PreludePhil
May 6, 2008 03:12 PM
dtran002
Nov 6, 2007 05:51 PM
Metal Head
Suspension & Brakes
Oct 18, 2007 10:21 PM
jeddy0120
Aug 7, 2003 10:16 AM
