shut off after start up?! Help!
Old Oct 24, 2002 | 10:53 AM
technine's Avatar
Default shut off after start up?! Help!
My civic is all of a sudden cutting out after it starts up for about 1 second. It starts then cuts off all of a sudden maybe 1 or 1/2 a second later after start up.
I'm thinking coil because when my ignitor went bad, I couldn't start at all, it would just turn and turn and turn. It lets me start it on the first start, but then it cuts out when it does. When I keep trying, eventually it starts and keeps running. Seems like it happens when cold. I know my battery and wires are OK because I still get power to power my starter and everything else.
Help!
Old Oct 24, 2002 | 11:32 AM
Perfectionist's Avatar
Default Re: shut off after start up?! Help! (technine)
When it dies after start up, do you get any panel lights like battery and oil? If not, I'd suspect the ignition switch.
Old Oct 24, 2002 | 12:02 PM
ImportHatch's Avatar
Default Re: shut off after start up?! Help! (Perfectionist)
fuel pump not turning on?
Yager-
Old Oct 24, 2002 | 12:24 PM
technine's Avatar
I get all lights that are normal. No CEL
Old Oct 24, 2002 | 12:25 PM
agent marlon's Avatar
Default Re: shut off after start up?! Help! (ImportHatch)
my car does the same also..im thinking its a fuel problem cause my car bogs big time when i drive it when its still cold..i changed my fuel filter and still had that problem..now im gonna change my fuel pump...
[Modified by 95 EJ, 9:26 PM 10/24/2002]
Old Oct 24, 2002 | 12:26 PM
technine's Avatar
I think the fuel pump is fine because it primes when in the on position and also my fuel pressure is up when this happens. It's @ about 40 psi when this happens. Seems like now, when I get it to run it runs fine no problems and it doesn't shut off on me. Seems like the problem is when it's cold. What else should I check?
Old Oct 24, 2002 | 12:27 PM
technine's Avatar
I also added an external fuel pressure regulator if that matters. It's been on for about 3 months with no probs though, but it's used.
Old Oct 24, 2002 | 01:09 PM
There is a Fast Idle Valve that is supposed to allow extra air into the intake for cold starts. Maybe yours isn't working? Normally, cold idle should be around 1700rpm.
Old Oct 24, 2002 | 03:38 PM
technine's Avatar
I think if the fast idle doesn't work the RPMs will be low or irradic. I don't think it will shut your car off after startup.
Old Oct 24, 2002 | 03:50 PM
sporkcrx's Avatar
where is the fast idle valve located? i've been having probs w/ my car turning off when i start it up too
dj_5
Oct 5, 2009 05:38 PM
soto2635
Jan 15, 2009 10:44 AM
cbstudd77
Dec 20, 2006 07:40 PM
jDm-Ek9
Jul 22, 2005 01:23 AM
silver hatch
14
Mar 29, 2005 05:08 PM
