"Rattling" noise from drivers side rear brake.
Old Jun 29, 2013 | 08:42 PM
Leviatard's Avatar
Icon6 "Rattling" noise from drivers side rear brake.
I have a '99 Honda Civic DX Hatchback, and its been a few months since I got my brakes done all round, and for the past few days its been making this rattling/grinding noise. It is more prominent as you hit lower speeds when slowing down from a higher speed. Anyone know what this could be? Had this problem? Any insight is helpful.
- Leviatard
Old Jun 29, 2013 | 08:45 PM
EsotericImage's Avatar
Retired Moderator
Default Re: "Rattling" noise from drivers side rear brake.
brake pad not sitting on brake cylinder correctly/not spread enough on the adjustment is my guess
Old Jun 30, 2013 | 12:42 PM
Custom93's Avatar
if you didnt replace the drums then it could be rust on the back edge rubbing on the backing plate i find it makes an almost swishing rotational noise that is more noticeable at low speed. if this is the cause tapping the flaking rust with a small hammer around the edge will knock it off and eliminate noises. hope that helps
manatee
14
Jul 27, 2012 05:09 AM
deerman2701
14
May 14, 2012 06:24 PM
GAngulo7
Honda Civic (2001 - 2005)
Jan 26, 2010 08:17 PM
99DXcoupe
Sep 24, 2002 09:28 PM
