Gauge cluster/ hazards not working
I've been putting what started as a rolling shell together and I have everything working besides the tach, speedometer, temp gauge, and hazards. I also get no check engine light when the key is first turned to the on position. Car is a eg hatch with a b16a. Cluster is for an automatic but i have been told that it doesn't matter. I have read in other threads that the cluster will not function unless the hazard switch is plugged in. The switch is plugged in but when I try to turn them on all I get is one click out of the relay and nothing from the lights. All of the blinkers work. I have replaced fuse #15 and fuse #19. I hate to post a thread but I am out of ideas, any ideas or input would be greatly appreciated
Re: Gauge cluster/ hazards not working
Dead battery definitely is not the problem, Hood fuse 43 is good, I cleaned the contacts on g201/401 grounds the other day. This thing has me stumped, are there any other grounds I may have missed?
Why/grn has no voltage, only wire on the plug that does is the yellow one. Also just figured out the blinkers don't work unless the switch is plugged in
Fuse 18 is voltage tested with the key in ON(III).
Hello, I am having a simular problem. I changed my instrumemt and radio harmess on my 93 del sol. It's a manual trans .the harness is for an automatic. Well, it all was fine after the install. A week later my hazzards in the back wouldn't blink and my gas gauge drops to empty when I start the car. I HAVE FILLED THE TANK and meter says full but when I start the car it drops to empty. I put on my hazzards with the car on or off and my gas gauge drops to pty. CRAZY RITE?
shivic
10-28-2010 10:56 AM
Jay.D.Em!
04-17-2006 07:17 PM
POLLO
05-15-2004 12:20 AM
