Transmission & Drivetrain Gearboxes, Differentials, Clutches
Shifting issues?! HELP!
Old Jun 29, 2013 | 04:28 PM
FRE5H BB6's Avatar
Default Shifting issues?! HELP!
Not too sure what could be causing this issue so maybe someone can help me. First of all its a 1998 Honda Prelude with an f20b swap, M2y4 Trans. 1st and second gear go in a little "clunky" and sometimes they go in fine, but for the most part you hear a "clunk" and its not smooth. All the other gears go in fine, and none of them grind. Then from time to time I have a hard to getting into reverse, when that happens I just move the shifter in a circle motion then it goes in gear perfect. Another thing I noticed is no matter what gear I'm in when driving if I let off of the gas the shifter moves like if it was to fall out of gear, when I hit the gas it moves forward again. I replaced my shifter cables with used ones but no results. Do I HAVE to get new ones from the dealer, or could it be the bushings at the end of the cables connecting to the trans? Or could it be another issue? Any ideas? Thanks!
FRE5H BB6
Jun 30, 2013 02:39 PM
6SPD_EK
Sep 11, 2006 05:05 AM
DC5SMunky
Aug 13, 2005 09:43 AM
Nevaeh
Sep 30, 2004 03:18 PM
hookeduphatch95
11
Feb 19, 2004 08:08 PM
