allways i hit boost the p/s belt gone
Old Jun 27, 2013 | 09:34 AM
carlos8's Avatar
Default allways i hit boost the p/s belt gone
hi guys, any of you have this problem ever, whenever I hit high boost in my
civic the p/s belt breaks or slid from the dampers.
Any help will be appreciate.
thanks
Old Jun 27, 2013 | 09:37 AM
grumblemarc's Avatar
The Grumpiest
Default Re: allways i hit boost the p/s belt gone
That's it? No other details past that?
Old Jun 27, 2013 | 09:42 AM
doctorake's Avatar
If you loved me, you'd all sell me your magic cards to me today
Veteran: Coast Guard
Community Builder
details as to car, motor, turbo setup????? Are we supposed to guess?
Old Jun 27, 2013 | 09:45 AM
The Grumpiest
WTF is high boost?
Old Jun 27, 2013 | 09:58 AM
carlos8's Avatar
ls vtec turbo, b16 head p&p 1mm+ valves type R cams, 5 angle with bowl blend, 81.5 SRP pistons 9.0:1 with FJT H beams, 404whp 289tq @ 18.5psi to3-to4 .60trim 63ar at
16.5 total advance. In 91oct gas (why lost the 93).
Any other question is received.
thanks for your response grumble.
Old Jun 27, 2013 | 10:07 AM
The Grumpiest
Are you sure the belt is tensioned properly? Is it OEM? Never heard anything about power steering belts popping off but then again most people seem to ditch it when they do turbo builds.
Old Jun 27, 2013 | 10:22 AM
carlos8's Avatar
no it's not a OEM belt, always a autopart belt within the spec. But always gates or goodyear. I try let the belt loose or super thigh, the same thing.
Old Jun 27, 2013 | 10:34 AM
The Grumpiest
Pulleys straight? Not really much more that it could be.
Old Jun 27, 2013 | 10:44 AM
B_Swapped93's Avatar
ditch the P/S imo, but i'd say make sure the belt is on TIGHT between the pulleys via that wing nut .
Old Jun 27, 2013 | 10:45 AM
carlos8's Avatar
serious grumble I see a little wave in the pulley. Maybe is my sight but my fellows partners in the shop say's it's all right.
how do I find a new p/s pump without know what is?
Maybe I can send you phone photo if you can help me ?
Old Jun 27, 2013 | 10:47 AM
The Grumpiest
I'm only guessing guy. I have an entry level boosted system. If this is indeed a problem with higher horsepower cars then I'm not qualified to speak on it.
Old Jun 27, 2013 | 10:54 AM
Marvin1985's Avatar
Try switching pulleys. The old one might be out of round or bent just enough that it snaps the belt.
Old Jun 27, 2013 | 11:02 AM
carlos8's Avatar
nice news my p/s damper (simbra) in WOT. I no know how is the word for that, It's like shaken in high REV's.
grumble if I send you a picture of my pump can you recognized it.
need to buy one.
Old Jun 27, 2013 | 02:16 PM
sleepyaccord96's Avatar
why am i not believing this
Old Jun 27, 2013 | 02:20 PM
i feel like it is a b18 stock ls thats throwing a belt or maybe i am wrong, i just had surgery so i am in a bad mood
Old Jun 27, 2013 | 02:21 PM
btw hp/tq/psi/turbo size have nothing to do with your ps belt or pump having a issue, something is offline (crooked) meaning one of the pulleys are not in check with the others which is why it spits the belt off at higher rpms. this is rpm related not "high boost belt problem"
Old Jun 27, 2013 | 04:22 PM
carlos8's Avatar
I just only want to solve my problem with the help of the guys here. if I put my setup is because they asked for it.
what's the difficult in such little build?
Old Jun 27, 2013 | 04:51 PM
replace the pulley and you will be fine man
tony tone
Oct 9, 2008 04:05 AM
Natural Aspirations
24
Nov 14, 2007 05:28 PM
JRZ88DX
16
Nov 13, 2007 03:56 PM
m.woo
Jul 29, 2007 10:50 PM
scooter
May 14, 2003 02:48 PM
