B series turbo kit for sale
This is a full bolt on kit off a running car with a built motor made 350hp and was daily drivin no issues at all the only reason it is off the car is because no one had a good offer for the car with the built motor and turbo kit so it was parted and sold like that.
Price is 1000$ firm
Included is
CoreyR mini ram manifold
CoreyR down pipe modded to bolt to stock exhaust
CoreyR dump tube
eBay .63 ar turbo was a recent upgrade (1000 miles on it )
38mm waste gate
Inter cooler
Charge pipes for eg coupe
Turbo smart blow off valve
Couplers
Clamps
Oil feed line
And all oil fittings
Dsm 450cc injectors
Aem wide band (75$ extra charge for this if wanted )
A Gsr oil pan that is tapped for this set up can be included for no extra charge only if a stock pan is supplied to put back on the motor if you can't supply a stock GSR oil pan then no oil pan will be included.
Also there is no ecu included if you don't like it sorry you couldn't use it any way your car needs its own tune and if the ecu was included it would not come with a chip. You need to have your own tune done for your car with your set up installed
Call or text 203-510-5445 for any questions or more pics or to set up a time to buy I am posting this for my buddy he is not a member on here and is not involved in the Honda game.
Price is 1000$ firm
Included is
CoreyR dump tube
38mm waste gate
Inter cooler
Couplers
Clamps
Oil feed line
Dsm 450cc injectors
i am not to sure what the psi was set at it had a holman boost controler (not included) so the boost was changed i posted it for a buddy his number is there if you contact him he might be able to answer it better
dirtySOHC's
May 22, 2003 07:28 PM
