02 sensor showing 0.0 voltage in Smanager?
All,
Trying to get all the kinks worked out in my fresh swap. Last thing seems to be that my 02 sensor shows 0.0 volts at all times in Smanager. No check engine lights or anything. Shouldn't smanager be picking up some kind of voltage for the primary 02? Fresh motor build so car has only idled and been around the block a few times to correct other issues. Car is a 97 CX hatch with a boosted b18c1 running s300. Stock injectors and map are on the car now just for initial start and correcting other issues. Right now I am running the preloaded p72 map in Smanager. Any input would be appreciated.
Thanks for the reply. I would assume if I still have 0.0 voltage at pin d14 then the wiring is messed up or my O2 is actually dead.
I appreciate your response. How high should the voltage go? I am just puzzled that my multimeter shows voltage but my laptop shows none.
FRKWOO
Jan 7, 2009 08:02 PM
blackouthx
16
Sep 26, 2007 09:05 AM
madlion
12
Sep 7, 2004 11:01 AM
