98 accord smoking bad at high rpm
Old Jun 26, 2013 | 02:06 PM
Kurt157's Avatar
Default 98 accord smoking bad at high rpm
i just bought a 98 accord with a 2.3 vtec. After about 4000 rpms it lets out th
a thick cloud of white smoke. Its bad enough that you cant see the vehicle beshind you. At low rpm there is no smoke and car runs good> Anu help would be appreciated thanks
Old Jun 26, 2013 | 04:43 PM
holmesnmanny's Avatar
Default Re: 98 accord smoking bad at high rpm
run a compression test on it
Old Jun 27, 2013 | 12:37 PM
Kurt157's Avatar
Im gonna try that. Thanks. Any idea what the compression should be?
Old Jun 27, 2013 | 04:44 PM
Michael_accord's Avatar
Your piston rings are going. If not already. Or piston ringlands cracked...something with ur piston/rings are broken letting oil up threw the head and threw the exhaust valves and burning oil is normally white.
Old Jun 28, 2013 | 01:12 AM
Kurt157's Avatar
I wonder why it only does it at high rpm and not all the time?
Old Jun 28, 2013 | 06:52 AM
You don't have as much pressure on the engine. For all we know it could smoke a tad you just don't see it because its not enough. At 4k rpm vtec engages fully which flows more oil to the head and at that rpm you have already build enough crankcase pressure.
Old Jun 28, 2013 | 12:39 PM
Kurt157's Avatar
That makes sense Michael. Im gonna do a compression test this weekend> Ill let you know tyhe results> Thanks for the input i appreciate it>
bucdenny
21
Sep 23, 2019 08:03 AM
athan
Oct 27, 2017 08:06 AM
95greenlude
Nov 3, 2007 04:21 PM
tianporn
10
Jul 20, 2004 11:24 AM
2nd Gen BlkDrgn
Jun 23, 2003 04:01 AM
