F20B Idle Problem 3000rpm
Old Jun 26, 2013 | 01:48 PM
nine23's Avatar
Default F20B Idle Problem 3000rpm
I have an 01 accord that I swapped a F20B into but the only thing is that when I start it up it shoots up to 3000 rpm and stays there... If anyone can help it would be greatly appreciated I need to get my car back on the road because I have a baby on the way!!
I pulled my codes and I'm reading 4 different ones... I got the codes from 6thgenaccord.com
3 - Map circuit high or low input
7 - tps
14 - ics malfunction, iacv failure
41 - front o2 sensor failor
I have...
Checked vacuum leaks
Cleaned IACV
Replaced tps
Replaced map
I don't have the cat back exhaust connected because I have to order new piping because of the New England rust but that shouldn't make a difference...
Old Jun 26, 2013 | 02:23 PM
nine23's Avatar
Default Re: F20B Idle Problem 3000rpm
Just checked the voltage to the power and signal wire for the tps and both are reading 5.2v
nine23
Jun 26, 2013 02:23 PM
bigpunn421
Mar 21, 2012 03:14 PM
99ek4Dr
10
Mar 2, 2011 06:22 PM
greenzchatch
Jul 29, 2010 02:14 PM
boostin1cam
Jul 20, 2005 05:39 PM
