error code 12 EGR on a d16z6??
Old Jun 26, 2013 | 01:01 PM
waynesumner's Avatar
Default error code 12 EGR on a d16z6??
i pulled an erroe code 12 and 3 on my d16 i now know the d16 doesnt have an EGR so would i be getting this code? could it be mistaken as 3? my check engine light blinks very dim and its hard to tell whether it pauses or just keeps blinkin. my SRS light stays blinking while running the codes? any ideas?
Old Jun 26, 2013 | 01:44 PM
grumblemarc's Avatar
The Grumpiest
Default Re: error code 12 EGR on a d16z6??
Why do you keep starting new threads for ongoing issues for the same unfolding problem? This is at least 3 now.
Maybe you should have posted a video.
Old Jun 26, 2013 | 02:26 PM
its not the same issue its an error code i got since i actualy got my car started! i havent said any thing about a distributor or getting spark from a distributor or timing a distributor sure its my fault i have issues with my car i would like to get sorted out so why dont you buzz off and do what you do. if you dont have a solution dont imply your opinion. or if you do have a solution and would like to be so kind and give your opinion please do but i suppose i already know your opinion it would go something like.......... quit starting threads about the same issue your flooding the forum.
Old Jun 26, 2013 | 02:29 PM
FAMz_DOMANi_MB4's Avatar
simplex ur ecu might be a for d15z1 cause vx has egr but has vtec done deal find urself a p28 ecu and stop making extra threads thank you
Old Jun 26, 2013 | 02:34 PM
well how do you find out what ecu you have and how am i supposed to figure out anything if i cant start new threads about it. isnt posting threads what a forum is for? to help people or get help with problems that arrise one after another. nobody is going to look at a thread that has already been delt with or doesnt have anything to do with a new problem.
Old Jun 26, 2013 | 02:40 PM
whats your ecu code?
and befor i switched out my HARNESS and DISTRIBUTOR i never had a CEL i never changed my ECU and all the connections are wired back how they were. plus the harness i got off of a d15 most likely didnt have an EGR and i know forsure didnt have VTEC because i had to wire VTEC myself
Old Jun 26, 2013 | 02:41 PM
and again whats your ecu code?
Old Jun 26, 2013 | 02:47 PM
37820-p06-L51
743610145
now i assume its a p06 due to the middle of the code up top. idk because i didnt install it.
Old Jun 26, 2013 | 02:49 PM
looks like something gone wrong with your p28 converted ecu
Old Jun 26, 2013 | 02:52 PM
ya it came out of a civic dx says a thread i came upon. now would it matter though?
Old Jun 26, 2013 | 04:32 PM
The Grumpiest
Since it is becoming extremely evident you are less than knowledgeable about your car than you should be, how about post a video so we can see what codes are being thrown?
This thread is just another part stemming from the original issue you posted about your car. The last two threads were about the distributor issue and car not starting which you claimed were BOTH caused because of an o-ring.
The core issue was that you somehow set your car on fire and EVERY issue you've had since then stems from poor attempts to fix the damage.
Only one damn thread was ever needed.
Old Jun 26, 2013 | 05:33 PM
no first i wasnt getting spark then then the spark plug wires were wrong then it was the o ring. lol it dont even matter anymore im trying to get the video up right now so keep your eye out.
Old Jun 26, 2013 | 06:05 PM
The Grumpiest
And all of that because your car caught fire.
Now put the video up.
Old Jun 26, 2013 | 06:27 PM
B_Swapped93's Avatar
lol^
but OP seriously you could have just kept updating your original thread and bumping if needed.
Old Jun 26, 2013 | 07:05 PM
I've done worse. I cant get the video uploaded ill keep trying but its a 3 manifold absolute pressure sensor and I cleaned the map sensor but it still shows up maybe its the #2 oxygen sensor but I only have one oxygen sensor and its on the header
Old Jun 26, 2013 | 07:15 PM
its on youtube, jump ahead to 9 seconds and youll get a better look at the code.
Old Jun 26, 2013 | 07:33 PM
are you using the correct ECU ?
Old Jun 26, 2013 | 07:42 PM
p06 from a 92-95 dx. I know its supposed to be a p28 but before all this occurred I never had a CEL and its all the same beside the harness and dizzy and its all wired up the same, is the SRS supposed to be going off like that?
stopltracr
Jan 25, 2016 04:35 PM
turboblack2door
Sep 2, 2008 01:10 AM
HA0LEFIED
Dec 13, 2006 04:04 AM
kamakaze1
Jul 28, 2006 11:06 AM
omgwtfhaxnub
Apr 12, 2006 10:26 PM
