Jdm B18c type r in 99 ex constant check engine light
Old Jun 25, 2013 | 07:01 PM
Miguel613ekb18c's Avatar
Default Jdm B18c type r in 99 ex constant check engine light
Ok so the swap is 96 spec jdm b18c type r in my 99 ek, the car runs good pulls really hard but there is a constant check engine light, I've tried to manually pull the code but engine light does not flash when I jump the service connector
My wire harness is obd2b
Obd2b to obd2a jumper harness
Obd2a p73-013 jdm ecu
Idles at 1100 rpm which doesn't really bother me
At first start up there is no check engine light, then after 10 seconds the check engine light come on and stays on which is really bothering me, is this normall for having a jdm ecu?
Old Jun 26, 2013 | 12:03 PM
HondaPartsHero's Avatar
Technical Hero
Default Re: Jdm B18c type r in 99 ex constant check engine light
Pull the codes and report back.
Old Jun 28, 2013 | 02:42 AM
TurboEM1's Avatar
yea im curious what the codes are. get an obd2 reader and post.
ondenoantra
Jul 13, 2024 01:08 AM
Teamdiesel
May 18, 2007 05:57 AM
greenDC2
Feb 25, 2005 09:41 AM
98teg
Oct 6, 2003 07:39 PM
Wayne64SS
Jun 26, 2003 10:01 PM
