Transmission & Drivetrain Gearboxes, Differentials, Clutches
Foolish to rebuild a working manual Transmission?
Old Jun 25, 2013 | 10:04 AM
netplaceus's Avatar
Default Foolish to rebuild a working manual Transmission?
I have a 1996 Honda Civic CX Hatchback with 245K on it. I am putting a rebuild engine in the car, should I have my manual 5 speed transmission rebuilt as well?
It works fine right now, but it only cost about $350.00 to have it rebuilt.
Some people tell me they never heard of one of these going out in a non performance car.
Or is this silly because I will need a clutch replacement again someday and I should just do it then if it needs it. I just want to make the car as reliable as possible because I sometimes take trips a long ways out and towing would be $$$$$$$$$$$$$$
By the way my stick shift moves about an inch when I am in second gear and accelerating. Never falls out of gear or "feels" like it is going to. Is this a symptom of problems to come or just normal.
Thanks for your advice!
Old Jun 25, 2013 | 01:40 PM
Runnerdown's Avatar
Default Re: Foolish to rebuild a working manual Transmission?
Transmissions certainly will wear out and need maintanence as well. The civic manual trans has its weak points, if a quality rebuild can be had I would do it. 350 is too cheap for a proper high mileage rebuild however.
Old Jun 25, 2013 | 02:07 PM
94EG8's Avatar
Seagull Management
The shifter moving under acceleration isn't symptomatic of a transmission problem, the engine and transmission move under acceleration and since the shift linkage, and by extension the shifter are bolted to it, they have to move along with it.
If it's not making any funny noises and shifts well with no grinding or notchiness there probably isn't that much point in doing a rebuild. $350 wont get you much a rebuild with shop rate labor and new parts.
Old Jun 26, 2013 | 05:28 AM
netplaceus's Avatar
Thanks for your help. By the way I made an error on the rebuild price. They told me it would be around $550.00. Hope that sounds about right. That is if I bring the transmission to them.
Old Jun 26, 2013 | 05:34 AM
netplaceus's Avatar
Well, there is a mild sound it makes when the clutch is down. I THINK it is more or less normal. Too bad I can just in cert a sound bite.
Old Jun 26, 2013 | 01:10 PM
94EG8's Avatar
Seagull Management
If it makes noise with the clutch pedal depressed (clutch disengaged) the throwout bearing is bad. If it makes noise with the clutch out (clutch engaged) in neutral it's a bearing in the transmission (usually the input shaft bearing)
You can, upload to youtube and simply copy and paste the URL into your post with no tags around it and it will embed.
Old Jun 27, 2013 | 09:45 AM
netplaceus's Avatar
Priceless advice, thank you! Sounds like throwout bearing, which is okay because I will have it replaced along with the clutch.
a2s2u2
Mar 20, 2017 05:45 PM
Blue92Civic
17
Oct 1, 2010 07:53 AM
fryman
Sep 16, 2008 10:10 AM
predut
Honda Civic (2001 - 2005)
11
Jan 4, 2007 07:48 AM
chrisknight
Jul 29, 2005 12:24 PM
