Manual Transmission Trouble
I have an ’04 Civic with a manual transmission, and for the past month or two it has been giving me difficulties trying to get into reverse. If I put it in reverse and try to back up, the engine will just rev about 50% of the time. When this happens, I have to put it in first, and then go back down into reverse to get it to work. Sometimes I have to do this more than once. It has also popped out of reverse at times. I took it to the Honda dealership to get them to fix it under warranty, but the claimed that this “normal” and that there is nothing to fix.
Is this the case? Is it normal to not be able to get in reverse gear about 50% of the time? Or are they just saying this b/c my warranty expires in 60 miles and they don’t want to fix it for free?
New User
Re: Manual Transmission Trouble (predut)
i think its normal, for me the only time i have toput it in first is in the morning after the car is warmd up i dont really need to how many miles do you have i belive its every 60,000 the tranny needs to be seviced i just did mine feels alot better too
Needs to be About 20% Cooler
1 Post
Re: Manual Transmission Trouble (em2!kid)
i got 80K on mine and it does this too. some times i'll put it in reverse and when i releace the cutch, it will lightly grind. if i take it out and pull harder on it going back in it works. only once it's poped out.
it also strugles to go into 1st or 2'nd when it's cold. i've found if i back out of the driveway then put it in second and cost down my hill, that must get the oil movin b'c 98% of the time is fine afterwards
i have no idea the mantance history on it. so i'm going to take it in for it's 80K checkup to the dealer.
You dont notice any slipping on the transmission? How many miles does your civic have? I bought a civic and it was doing the same thing and latter i found out the transmission was worn out. (Someone didnt know how to drive manual )
1 Post
Re: (toyomatt84)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toyomatt84 »</TD></TR><TR><TD CLASS="quote">Here's a tutorial I just wrote up.
http://toyomatt84.proboards50....67280</TD></TR></TABLE>
You need to take off that 6 speed shift know until u get ur K in there:p
Sanji
Re: (Vantage)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vantage »</TD></TR><TR><TD CLASS="quote">
You need to take off that 6 speed shift know until u get ur K in there:p</TD></TR></TABLE>
How did I know that someone would spot that? Jeesh, I'm just into saving money. Why buy two shift *****?
With my 05 Civic when i put it into reverse and my car was on a downhill slope, it would slip out of reverse unless i really jammed it into the gear. I told honda and they replace the bushing for my transmission, been great ever since.
netplaceus
Transmission & Drivetrain
06-27-2013 09:45 AM
fryman
09-16-2008 10:10 AM
