Transmission & Drivetrain Gearboxes, Differentials, Clutches
Checking an ITR Differential
Old Jun 23, 2013 | 05:41 AM
7rrivera7's Avatar
Default Checking an ITR Differential
I'm rebuilding my YS1 cable transmission due to a slight grinding of 3rd gear during high shifts and I'd like to test the differential to make sure it's working properly. Is there a visual inspection? If I remove the ring gear screws, if their a way of making sure everything is fine besides just a visual inspection of the internals?
Old Jun 23, 2013 | 03:25 PM
7rrivera7's Avatar
Default Re: Checking an ITR Differential
Anyone with pointers on inspecting an ITR LSD?
Old Jun 26, 2013 | 08:10 AM
7rrivera7's Avatar
Can anyone give me some pointers?
Old Jun 28, 2013 | 03:32 PM
lazmashery's Avatar
I dont mean to be rude but if you're posting this, you probably shouldn't tear into the differential. If you just want to learn its ok I guess, but be very careful. There is a series of clutches in the differential, the only this you can do is take them out and remember their order(fairly easy). Clean all the discs and re-install after visual inspection. You should be able to see the lines on the clutches just like you would on a regular clutch, except these are steel. Hope it helps.
Oscar
Old Jun 28, 2013 | 04:32 PM
Salami's Avatar
Oscar
I don't meant to be rude but it you are posting this, you should give accurate information. There are no clutch discs in an OEM ITR B-series differential. It is very easy to disassemble and reassemble.
Black R
Mar 9, 2017 09:11 AM
7rrivera7
Mar 28, 2015 05:50 PM
red civic standard
Mar 6, 2007 02:27 PM
