Shifter too sloppy
Old Jun 23, 2013 | 03:50 AM
Mishako129's Avatar
Default Shifter too sloppy
Hey yall, good morning. I am in the process of almost completing the 5 speed swap... I have one problem though, the shifter is way too sloppy. It will shift into gears fine its just it feels like its in neutral. I can eve rotate it a little diagonally.
Does anyone have a quick DIY solution to this problem? I looked already and can't find the answer to this.
Thanks.
Old Jun 23, 2013 | 12:19 PM
NZXTInerTia's Avatar
Default Re: Shifter too sloppy
Maybe you should ask Honda-Tech.
Oh wait.
Old Jun 23, 2013 | 02:24 PM
nicolaselias's Avatar
Loved
Community Favorite
Man..... Didnt we all say 100 times just to create one swap thread?
I don't have an answer for you, but you will be much more likely to get help if you didn't ignore people's advice
Old Jun 23, 2013 | 08:07 PM
Mishako129's Avatar
Oh wait.
have you got a demon in you?
Old Jun 23, 2013 | 08:08 PM
Mishako129's Avatar
How have I ignored peoples advice? Stfu you people are so retarded.
I have looked for answers to this question and cannot find any and i'm not going to make another swap thread.
Old Jun 23, 2013 | 08:49 PM
Out of the what two? No, three. Three threads that are semi informative. Make a damn thread for all the ridiculous stuff you post. Now you're calling us retarded? Get a damn life kiddo, you really need one. If you weren't able to find it online anywhere else, why in the hell do you think we would know?
Process of elimination. Find out what could be causing your issue and fix it.
Old Jun 23, 2013 | 08:59 PM
lostforawhile's Avatar
longest project ever
From: on the south side of dixie, 1986 Accord Hatch
take the shifter out and rebuild it, since this is supposed to be one of many threads, and nothing is mentioned of what car, I cant tell you more then that
Old Jun 23, 2013 | 09:11 PM
He drives some 4th gen wagon. That he's "attempting" to manual swap.
Old Jun 23, 2013 | 09:15 PM
if it's still the non cable setup, it's the rear shift assembly bushing and probably the torque rod bushing, they should be the same as any other fourth generation and I believe energy suspension makes a civic kit that fits
Old Jun 23, 2013 | 09:16 PM
DeadlockRiff's Avatar
Look, if it's not moving more than 1/4-1/2 inch each direction while in gear, you're good. If more than that, check your shifter base bushings and then move on to check the cable bushings (on the transmission).
If it turns out you just don't like the freeplay as a result of the soft oem bushings, get Bronzoil bushings from TWM or aluminum bushings from Corsport. (Cable bushings)
If that's not enough, order the Shifter base bushings from TWM for the 97-01 Lude [USDM]. They are the same as the 90-97 Accords and 92-96 Ludes.
Old Jun 23, 2013 | 09:18 PM
does that one have a cable shift or the rod shift and torque rod?
Old Jun 23, 2013 | 09:22 PM
I can't remember if that has a cable shift or not, if this helps, this is when I rebuilt my entire shift assembly on my third generation, maby you can get some useful info from it http://www.3geez.com/forum/performan...k-again-4.html
Old Jun 23, 2013 | 09:23 PM
Cable shifter.
92-01 Ludes and 90-01 Accords. Not a clue into the other models outside of these years, I could check but there's no reason to.
Old Jun 23, 2013 | 09:25 PM
Originally Posted by DeadlockRiff
Cable shifter.
that sucks, they shift so nice with the early shift rod shifters when everything is rebuilt
Old Jun 23, 2013 | 09:28 PM
Loved
Community Favorite
To think you just insulted one of the few people who attempted to offer non-cynical advice prior to this....
Good luck fool
krazykay5487
Jan 7, 2007 03:50 AM
reg4life
Apr 7, 2006 02:34 PM
ghost_ryder35
Jul 17, 2005 10:54 AM
AzntstyleZ
Jan 12, 2004 09:37 AM
SpeedMonkeyRacing
Dec 14, 2002 09:43 AM
