Best turbo kit
Im finally looking to put a turbo kit in my 96 b16a2 swapped hatch. Ill start out by saying it is my DD and i'm by no means looking to run some crazy amount of boost. Correct me if im wrong but i've read that if you keep it under 7psi then there is no need to change internals. Also the kit does NOT need to be PS or AC friendly. Finally and most important, budget. Looking to stay under $2000 if possible. Looking for advice from people that actually have a turbo installed.
http://www.go-autoworks-store.com/gostkit.html
you would still need an adequate form of engine management as well ie. hondata, chipped ecu w/chrome/Neptune etc
u can also piece together a kit yourself for well under $2k if you know what your looking for.
Last thing, you should not base things off your psi. psi levels are different for each turbo. you should set a whp goal instead.
you wont get advice if you don't do some research on your part
OP:
keep searching and reading the FAQ because its apparent that you dont understand that boost/psi/lbs has nothing to do with anything. not trying to be rude but going into the turbo realm isnt always friendly
if you want to create power where it doesnt exist, your going to have to spend the money to get there. modding vehicles isnt cheap, you can do i/h/e and think you have massive gains. all real power is made internally, which means you have to spend real money and spend some real time looking to what you want to do
big-cat
Apr 6, 2006 04:16 PM
