anyone else running both an exaust evacuation system and a PCV?
Old Jun 20, 2013 | 12:46 PM
lostforawhile's Avatar
longest project ever
From: on the south side of dixie, 1986 Accord Hatch
Default anyone else running both an exaust evacuation system and a PCV?
I was wondering if anyone else is running a combined exhaust evacuation system and a PCV? I thought about this idea because the PCV works best at lower RPMs and the exhaust system works best at higher RPM's when the PCV fails, my main concern was the fact that PCV valves tend to leak, and at wide open throttle when manifold vacuum drops to zero, I was concerned mixture could be pulled into the exhaust. I fixed this issue with an aviation quality check valve, in line with manifold vacuum going to the PCV. I just built an oil separator to go with the factory one, to ensure all the garbage doesn't make it into the manifold.
factory separator
Old Jun 20, 2013 | 12:50 PM
Default Re: anyone else running both an exaust evacuation system and a PCV?
Old Jun 22, 2013 | 09:32 AM
I thought this might be an interesting discussion since the pcv only really works near idle
'90crxSI
Sep 14, 2008 05:38 PM
dpkelly
Aug 15, 2005 08:52 PM
94lsboost
Feb 3, 2005 09:08 AM
TurboIntegra
Sep 28, 2002 10:29 PM
Redline130
Feb 23, 2002 05:21 PM
