97 civic hx having problems not sure what to do?!? Please help
Old Jun 20, 2013 | 08:12 AM
Drewski88's Avatar
Default 97 civic hx having problems not sure what to do?!? Please help
Okay so this is the problem, the other day I was on the highway and it started to over heat. When I opened the hood the motor was covered with anti freeze. Wasn't really sure what the problem was. I changed out the thermostat. Checked the old one(put it in boiling water) it opened up somewhat but no fully. So I put the new one in. Drive it around town for a few. No overheating problem. As soon as I bring the speed up to about 55 it starts to over heat. Not sure what the problem is. Then here is the next thing that is mind baffling to me. Got it home. Let it cool. Went to start it nothing. Wasn't getting spark? Later that night cranked it over and it started right up. Next morning same thing. And I turned it off it would not start after driving it for about 10-15 minutes. Any advice? Already checked the fuses and replaced the main fuse relay on the passengers side by the glove box( it was making a clicking noise when I turned the my over with out cranking the motor)
Old Jun 20, 2013 | 08:16 AM
grumblemarc's Avatar
The Grumpiest
Default Re: 97 civic hx having problems not sure what to do?!? Please help
Think critically here. If coolant is on the OUTSIDE of the engine wouldn't it follow that the only way that would happen is if there were a leak somewhere?
Did you check the hoses or radiator for leaks?
I'm guessing your letting t overheat did some damage.
Old Jun 20, 2013 | 08:26 AM
Former User's Avatar
Overheating - did you bleed the cooling system after replacing the thermostat?
Intermittent no start - is this a no-crank problem or a cranks-but-won't-start problem?
Old Jun 20, 2013 | 08:27 AM
Drewski88's Avatar
That is the thing though. While it is idling there are no leaks. No leaks when it is shut off either
Old Jun 20, 2013 | 08:29 AM
Drewski88's Avatar
Also I did bleed the coolant system after changing the thermostat. So there wouldn't be any air pockets in the block
Old Jun 20, 2013 | 08:35 AM
How did you bleed?
No crank or cranks but won't start?
Drewski88's Avatar
And it cranks but no start. After it has been shut off and ran. Maybe it got the distributor wet? That was my thinking but I'm not sure.
Old Jun 20, 2013 | 08:36 AM
Have you checked for CEL codes?
Old Jun 20, 2013 | 08:42 AM
Drewski88's Avatar
Opened the radiator cap filled radiator. Let it run with out the cap on to let the air bubbles release and then i filled it back up.
Old Jun 20, 2013 | 08:45 AM
How long?
CEL codes?
Old Jun 20, 2013 | 08:47 AM
Drewski88's Avatar
Haven't checked the cel codes I let it run for about 5 minuyes
Old Jun 20, 2013 | 08:50 AM
Redo bleed and let engine run until radiator fan turns on twice.
Check for codes. Click the Codes link in my signature.
Old Jun 20, 2013 | 08:54 AM
Drewski88's Avatar
Okay will do when I get off work. I will let you know once I check codes
Old Jun 20, 2013 | 10:49 AM
Drewski88's Avatar
So no codes are coming up. I'm stumped lol. Guess I will just have to start it up and have one of my friends watch for leaks while I give it a steady rev. Maybe I can find the leak that way. It's just so weird.
Old Jun 20, 2013 | 11:10 AM
Next time the engine won't start:
1. Listen for whether the fuel pump primes.
2. Check for bright white spark at all 4 spark plugs.
JasonST
15
Mar 10, 2022 08:46 PM
shemarienp
Aug 20, 2009 06:19 AM
SOHC_civic_si
34
Jul 28, 2009 07:55 AM
kitkatR
Oct 31, 2004 07:15 PM
