B16A troubles
Old Jun 19, 2013 | 09:04 PM
TiltBoxTurns's Avatar
Icon2 B16A troubles
I have a 1988 Honda CRX with a 1991 B16a and a 95 Civic DX Ecu engine swap (done before i got the car). It ran great for a year then it started dying intermittently but it would either start right back up or have to sit 5 minutes then it would start. I thought maybe it was something overheating like the fuel pump or the distributor and went to check by driving it til it warmed up and died (so i could test the CEL) however it died less than 2 miles from where i started and it didn't have time to warm up. I did try checking the CEL but it wouldn't give me any error codes. I've run out of ideas. Please help
Old Jun 20, 2013 | 03:15 PM
2kdrift's Avatar
Default Re: B16A troubles
ignitor inside of dizzy...did u test for spark? fuel?
Old Jun 23, 2013 | 01:48 AM
It only ever died while driving so one of the time I killed it I tried introducing either via the air intake however I did not try testing the spark. I supected the ingitor because the trouble was intermittent. I belived it might be going bad and was stumbling when it warmed up. I will check for spark in the morning.
Old Jun 27, 2013 | 04:13 PM
was going back over what I've learned and figured out that the Ecu is not from a civic Dx its from either a a civic si or Ex. its a p28 ecu
Old Sep 1, 2013 | 04:55 PM
i finally got the car to show an error code. its ingnition output signal
EFjoe91
13
Nov 25, 2015 05:02 AM
fastlimegreencivic
Dec 25, 2012 12:01 AM
Ueichi
Jul 28, 2012 05:38 PM
jesiaczek
16
Sep 30, 2011 04:35 AM
JDMcrxb16a
Jul 13, 2005 08:33 AM
