Innovative MTX-L with Crome Pro 1.6.5 - wideband vs datalogs - offset?
Old Jun 17, 2013 | 09:39 AM
Black R's Avatar
25 Year Member
Default Innovative MTX-L with Crome Pro 1.6.5 - wideband vs datalogs - offset?
Hi,
I have an Innovative MTX-L and Crome Pro 1.6.5
I have noticed that the wideband gauge is showing different readings vs the datalogging on the laptop when I compare the two simultaneously.
Is there an offset somewhere?
This is on a p28. I'm using the yellow wire from the MTX-L output, and have not made any changes to the output.
Is the p28 expecting a slightly different voltage range?
Old Jun 17, 2013 | 05:39 PM
GhostAccord's Avatar
Default Re: Innovative MTX-L with Crome Pro 1.6.5 - wideband vs datalogs - offset?
Go into File/Settings/Tuner Logging (tab) and adjust the Lambda offset until it matches your gauge readings.
Old Jun 17, 2013 | 06:01 PM
bgdriver's Avatar
is the wideband grounded to the thermostat?
Old Jun 17, 2013 | 06:33 PM
Black R's Avatar
25 Year Member
No, I grounded to the chassis.
But the thermostat is also grounded to the chassis.
You think that's it?
Old Jun 17, 2013 | 06:34 PM
Black R's Avatar
25 Year Member
I already did that.
What voltage range does the Honda ecu look for from the stock o2 sensor?
Old Jun 17, 2013 | 06:50 PM
Black R's Avatar
25 Year Member
I did some digging and the default outputs for the innovate are yellow (0v=7.35afr and 5v=22.39afr) and brown (1.1v=14afr and .1=15afr).
I went back into Crome and I can't decide whether to change the output of the wideband or what Crome expects.
What do you guys suggest?
* I went ahead and changed the settings in Crome for tuner logging to Innovate and then just plugged in the numbers for what the default Innovate pulldown has and saved the changes.
What about the lambda recording conditions range?
What do you guys put in there?
If all else fails, I guess I can readily apply the offset lambda correction too.
Old Jun 18, 2013 | 02:23 AM
If the drop down scalars in Crome do not match what you have for your widebands specs, I would change them.
As far as the lambda recording conditions go. You can change them to whatever you want. Depends on where you want to record your AFRs. I have mine set so that it will record pretty much all the time.
Throttle: 0-100%
Lambda: 0.60 & 1.20
Engine speed: 0-10,000 RPM
Engine load: 0 - 3000
Water Temp: 40 - 250 °C
Gear(s): 0 1 2 3 4 5
X2BOARD
Dec 7, 2007 08:16 AM
l1bid0
Apr 15, 2007 05:43 PM
Used2beAb16
May 15, 2005 09:31 AM
Boost3d22
Mar 13, 2005 06:16 PM
photonjedi808
25
Apr 17, 2003 12:08 AM
