90 crx si b16 turbo manifold help
I do not have the a/c or ps. I have swapped to the half radiator. Is there a turbo manifold that will place my gt3582 in a place so I dont have cut something? If so what manifold and could I see some pics. I have a cast log manifold and tubular top mount. Cast puts the turbo in the radiator and the top mount puts the intake side against the dr side headlight.
Honestly, a lot of shops can make you a custom manifold. You just need the pieces from a different manifold that bolt to the turbo and the exhaust flange. Then they can make a tubular manifold that will fit your specs.
If it's a good shop they could cut the flanges in shop and you wouldn't have to supply your own.
I've used an InlinePro manifold with everything from a T3/T4 up to a BW S372. Never had fitment issues with my headlight or radiator. Of course, being in an EF, you do have to be creative at times to make everything fit.
im running a ccfab mini ram and no fitment issues at all. but im also running an innovative crossmember. like redline130 said. ya gotta get creative with these chassis
checked through these pages?
https://honda-tech.com/forums/forced-induction-16/%2A%2Aofficial-boosted-ef-thread%2A%2A-1771468/
Who is Mr Robot?
Any cast manifold like the inline pro should work fine as do most mini rams. Anything different and you run into major clearance issues
Who is Mr Robot?
And as far as a turbo that large.... it will be very very laggy especially on a b16. You're better off sticking with something in the 3076-32xx range for a streetable turbo that makes decent top end but isn't nearly as laggy and a dog to drive all the time
nitronaught6969
Jun 21, 2008 06:38 PM
