help identify turbo for rebuild kit purchase
Old Jun 15, 2013 | 02:17 PM
supersilverdc2's Avatar
Default help identify turbo for rebuild kit purchase
can someone please help me identify this turbo?
Old Dec 2, 2013 | 11:55 AM
Default Re: help identify turbo for rebuild kit purchase
bump ?
Old Dec 2, 2013 | 12:21 PM
TheShodan's Avatar
Moderator
That's just the backplate number. Looks like a BW compressor cover for the smaller 46 trim GT3271 turbo, using a stage III exhaust wheel. 99% sure its a T3 turbine "small" shaft using a 270* thrust bearing.
What "kit" do you get? .. More than likely your standard 270* "T3/T4" full Garrett rebuild kit. But you get a GARRETT rebuild kit, not a Borg-Warner.
No more bumping.. give it a shot and good luck.
Old Dec 2, 2013 | 12:33 PM
I have not got a kit yet, this will be my first turbo rebuild, I have the other one on the car which is exactly the same, but stamped garrett on the intake side..
both are leaking a small amount of oil
Old Dec 2, 2013 | 02:40 PM
wantboost's Avatar
Who is Mr Robot?
You can't rebuild it on your own entirely... it needs to be rebalanced...
and you can get a 360* thrust bearing upgrade... That CHRA is pretty standard on all of the older "T" series turbos
Old Dec 2, 2013 | 03:10 PM
I see....
come to find out I have asked around and nobody round these parts wants to balance a turbo , let alone rebuild one...
I am going to get a CHRA replacement from ATP turbo in Hayward Ca....
It seems to be easier, yet a replacement costs about $630 out the door....
Old Dec 2, 2013 | 03:46 PM
TheShodan's Avatar
Moderator
Originally Posted by supersilverdc2
I see....
umm, the CHRA replacement will more than likely NOT fit what you have, and will require machining in order for that compressor wheel from the new cartridge to fit that compressor cover. that will cost even more in resources as you neither have a 50, 57, or 60 trim compressor cover to fit that. You're better off getting it sent for rebuild and repair (about $375 or so from reputable Garrett repair dealers) or get another turbocharger entirely, which means it could be ANY of the above turbocharger plus possibly others depending upon what you're trying to use the turbo for (power goals, use of the turbo, etc..)
What you purchase from ATP turbo WILL NOT FIT what you have there at all.
Old Dec 3, 2013 | 07:43 AM
wantboost's Avatar
Who is Mr Robot?
Yea a CHRA replacement is more for GT series turbos.
Now you can get a replacement "T" series CHRA like yours but it will be unloaded, that is, no bearings or seals, no wheels.
As far as balancing, look for a diesel shop around you, because most service mainly turbo diesels they normally have an in-house balancing system (or someone local that does it for them)... I know the turbo diesel shops around me normally charge 80 bucks to do a centrifugal balance on a cartridge/wheel assembly and they do good work.
Thats my suggestion, otherwise you'd have to ship the unit out to some place online (eek!) as most online places are hit or miss when it comes to proper balancing practices
cheetah64
Feb 19, 2011 10:38 AM
Eklsv-t
Dec 9, 2007 03:06 PM
rudebwoy
Sep 25, 2006 10:20 AM
x2gold
Apr 19, 2003 01:55 PM
rice4life
Jul 15, 2002 02:09 PM
