Help idle issue. Yea i know right. Help
Old Jun 14, 2013 | 02:30 PM
mikeyleed's Avatar
Default Help idle issue. Yea i know right. Help
I low there is a sticky about this. I've read it 10 times. I've looked over everything. My idle still has the womp womps. Can anyone give a hint or has anyone had this problem constantly. It loud. It's annoying. An people think I keep trying to race them or revvin at them. I have a ls swap in an eg hatch, if that helps any. Thanks
Old Jun 14, 2013 | 02:38 PM
mattyfo0z's Avatar
Default Re: Help idle issue. Yea i know right. Help
womp womps meaning your idle is going up and down? i'm assuming you've already gone over your entire engine bay with a fine tooth comb looking for this vacuum leak (which is my assumption the problem is)?
Old Jun 14, 2013 | 02:47 PM
mikeyleed's Avatar
I hope your not being a smart ***. I'm looking for serious help. Like I've said I've done everything. The only thing I haven't done was a smoke test.
Old Jun 14, 2013 | 03:34 PM
hoorah's Avatar
What year is the LS motor, does it have a coolant port at the throttle body? In actual fact...not being funny...is your womp womp a fluctuating/hunting idle??
Old Jun 18, 2013 | 01:54 AM
Buckshot870's Avatar
Most likely IAVC
Or coolant level / coolant level sensor
Old Jun 18, 2013 | 04:18 AM
silkypillows's Avatar
internal or external vacuum leak.
a few likely potential causes:
FITV too far open
cracked vacuum lines/leaking gaskets/open vacuum ports
IACV dirty or sticking
Idle set/air mix screw out of OEM spec
I would lean towards FITV if no vacuum leaks were found.
Old Jun 18, 2013 | 05:04 AM
Joshka89's Avatar
try the good ol wd40 bubble test
hatchnewb
Mar 3, 2013 04:05 AM
_kiid
May 7, 2009 03:01 AM
majorpain
Mar 23, 2009 01:39 PM
nekoabandoned
13
Feb 12, 2006 12:52 PM
deeweezy187
Dec 3, 2005 08:50 PM
