AAAAHHH!! Lights come on , But del sol wont turn over/start
Old Jun 14, 2013 | 08:38 AM
romomatic's Avatar
Icon2 AAAAHHH!! Lights come on , But del sol wont turn over/start
I need help. I've got a 94 honda del sol that ramdomly wont start. It starts when it cold. But if its been running for a while or if the weather is hot, It wont start. I turn the key and the lights come on, but the car doesn't turn over. You can hear a clicking sound near the relays under the dash.
in the last 9 months:
I have replaced the main relay.
I have replaced the starter
I have replaced the battery and terminals
I have replaced the distributor
Im at a loss right now. If you have any ideas, please let me know.
Old Jun 14, 2013 | 08:51 AM
Former User's Avatar
Default Re: AAAAHHH!! Lights come on , But del sol wont turn over/start
No crank problem, right?
Clean/tighten the G3 transmission ground wire, check the rubber stopper that presses on the starter switch at the top of the clutch pedal, and also test the ignition switch.
Old Jun 14, 2013 | 10:31 AM
Joshka89's Avatar
Try arcing the starter when it's warm.
See if it cranks.
If it cranks at this point then you know it's a relay between ignition switch and starter.
If it still doesn't crank then it's something after the starter.
That should help.
Also read the start issues FAQ its got a lot of stuff in it
Old Jun 24, 2013 | 12:57 PM
romomatic's Avatar
Thanks for the advice. I think I may have fixed it. Both stoppers on the pedals crumbled to pieces. I've replaced them and haven't had an issue since. If something changes I'll let you know. Thanks for the help
twj815
12
May 27, 2020 09:39 PM
BlueVxIDelSlo
45
Sep 23, 2017 02:50 PM
rnuts
Jul 20, 2017 11:33 AM
1point8DelSol
Feb 24, 2013 08:48 AM
luther
Sep 13, 2012 11:08 AM
