Dead 96 Del sol
Dead 96 Del sol
My honda del sol is completely dead- I have been working on this for 10 days already- It started with the del sol stalled and went dead while I stop for traffic lights then eventually it won't turn on at all. The car will turn on if I popped the clutch. I have went through and replace the battery, spark plugs, ignition coil, the main relay, the plastic bushing for the clutch and the starter. The car will only turn on with a push start by popping the clutch. the electrical components are on and AC is running. The car doesn't even crank. Just complete silence.
Please help!!
Please help!!
I like the tuna here
Re: Dead 96 Del sol
Could be ignition switch, could be grounds, could be that little starter solenoid spade connection not being on tight. Like Caoboy said, look for 12v at the starter and start working your way backwards.
Re: Dead 96 Del sol
First you should try jumping the starter. Leave the key off. Set the hand brake and make absolutely sure the transmission is in neutral. Unplug the wire from the little terminal on the starter. Take a test wire and jump from the little terminal to the + of the battery. The engine should crank. It won't actually start, because the key is off, but that's not important. This test shows the battery, starter, and the connections between them are OK.
If jumping does work then you would look at the little terminal being loose as someone mentioned, the clutch switch, and the key switch. There are no fuses between the key switch and the starter. If someone installed an aftermarket alarm with a "starter cut" feature, that could be the problem. All the wires involved are fairly heavy and colored black with a white stripe.
-Intl Steve Krew
Re: Dead 96 Del sol
I got a new ignition switch and the car still not turn on. So I'm moving on the the fuel pump. I do hear humming sound when I turn the key and I do see fuel leaking from the fuel filter. What else do you suggest?
Re: Dead 96 Del sol
donnieb22000
12
10-22-2016 09:13 AM
911awesomeness
18
12-09-2013 08:12 AM
romomatic
06-24-2013 12:57 PM
