94 Honda Civic Lower Control Arm change.
I am changing the Lower Control Arm on my Civic this afternoon on the passenger side. One of the main bolts that bolt the Control Arm to the frame will constantly spin inside the control arm. I cannot get it to back out of tighten up. Any suggestions on how to get this out?
if you follow the Front LCA toward the Center of the car it bolts up with 3 bolts at the subframe which bolts up the "compliance bushing assy"
the LCA on the front has a single bolt also... come to think of it without looking at my subframe i cannot recall which bolt he is talking about.
There's is no way to avoid it. It happens. It's called rust. The only thing you can do is use anti-seize on new bolts or bolts that you can successfully remove and reuse.
scheibler
Feb 11, 2025 03:36 PM
corkss
10
Mar 19, 2009 07:00 PM
Hondapreludeg
Jan 20, 2009 02:35 PM
Hondapreludeg
Jan 19, 2009 09:46 PM
ActiveAero
May 14, 2006 10:22 AM
