white smoke from tail pipe
Old Jun 13, 2013 | 07:51 AM
integra_101's Avatar
Default white smoke from tail pipe
1992 prelude with 1993 jdm h22a engine
The engine light is NOT on
the coolant had always been at level. i see no loss in coolant
The car has been sitting since February. Only started it once a week.
I let it get to operating temp today. once at operating temp, the white smoke was still coming out. along with black water.
I am going to do a compression test. If I do that, will it 100% determine if I have a bad head gasket?
The smoke coming out of the tail pipe smells burnt and when i changed the spark plugs, they were black.
thanks
Old Jun 13, 2013 | 10:56 AM
minilogoguy18's Avatar
Default Re: white smoke from tail pipe
Easy way to tell is to put a coolant funnel on the radiator and let it run, if you see a constant stream of bubbles at operating temp then you have a bad head gasket.
Old Jun 13, 2013 | 05:09 PM
Thanks. I'll try that.
Old Jun 13, 2013 | 06:29 PM
Sparksman's Avatar
Only three colors will come out of the tail pipe. Black- fuel, Blue/purple-oil, White-coolant.
It may just be a small leak now, but i wouldnt doubt it gets worse the more you drive it.
Old Jun 14, 2013 | 08:44 AM
so i started the car again today, and no white smoke on start up.
i didnt let it get to operating temp but that doesnt matter if a head gasket is blown.
i also put a funnel in the rad and brought the car up to 2500rpm a few times. no bubbles.
Old Jun 14, 2013 | 12:05 PM
TheJGB3's Avatar
Sounds like condensation in the exhaust burning off. When you shut the car off at operating temp, when it cools down water condensates in the pipes. Then the next time you start it you experience that while it is burning off.
Old Jun 15, 2013 | 01:35 AM
holmesnmanny's Avatar
A compression test would clear up any doubts or guesses.
Old Jun 15, 2013 | 11:26 PM
jwarren1904's Avatar
Yeah this is best case scenario. I work overnight and when I start her up around 5am to leave she puffs out some white smoke. If it's been sitting in a garage then disregard this, unless condensation manages to make its way inside
Old Jun 16, 2013 | 02:07 AM
It's normal to have white smoke in cold weather but the smoke should dissipate with a couple feet..it shouldn't for 5 feet or more and not dissipate.
Old Jun 17, 2013 | 06:52 PM
yea it will come out of the tailpipe for about 5 feet, then disappear. Its not thick white smoke either. Its like fog.
Old Jun 17, 2013 | 07:13 PM
jmoua89's Avatar
I drive an integra with h22a swap and during cold weathers my car will smoke out white fogs. After it warms up it'll go away. One other way to tell if the head gasket is bad if you leave the radiator cap open and start the car and see if it shoots up coolant. I've done this many times and it never fails.
Old Jun 17, 2013 | 08:14 PM
it doesnt shoot up, but it will overflow and go all over the rad.
Old Jun 17, 2013 | 10:22 PM
Just let it warm up if you don't want to do a compression test. It will be more obvious if it's still giving white smoke after the car is warmed up fully. There should be no white smoke at all at that time.
Old Jun 18, 2013 | 03:42 AM
He pretty much told you a ghetto version of what I already suggested, the radiator will of course overflow without the cap, liquid expands and eventually evaporates into a gas when heated enough, that's why the overflow tank is there.
civ97
Mar 31, 2009 07:56 PM
949
19
Mar 22, 2009 10:04 AM
gunterelectric226
Dec 3, 2008 06:49 PM
chu77
May 25, 2006 07:55 AM
RCautoworks
Sep 6, 2005 11:08 PM
