No reverse light
Bottom of the transmission, passenger side, there should be a switch with a very short set of wires coming out leading to a plug. That is your reverse switch. Is it there, and is it wired to anything?
Since you converted it from auto to manual you need to run wires from the switch on the tranny to the auto shifter plug. The green and yellow wires are for the reverse lights.
I'm not 100% sure if this will work or not but try tieing the wires together first and see if it works. If not then you gotta do what I said above.
bpatterson6003
Apr 14, 2009 10:00 PM
blackfoot
Nov 6, 2007 04:10 PM
x still jaded x
Jul 4, 2005 10:49 PM
