Replacing valves
Old Jun 11, 2013 | 01:22 PM
Boyle.R's Avatar
Default Replacing valves
So my timing belt broke and I ended up bending some valves question now is do I replace the bent valves with OEM or upgrade the lot to aftermarket valves. Opinions welcome
Old Jun 11, 2013 | 06:40 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: Replacing valves
Unless the oem size replacement valves have a back cut stem, allowing for more airflow then no. simply replace the bent valves and lap them into place using a lapping compound and a lapping valve tool. Some people cut the seats oversized, say one millimeter and then run half millimeter bigger valves than oem, they seat just fine but you actually get more air into the cylinder since there's less valve in the way. Call it an old racers trick
Old Jun 12, 2013 | 01:41 AM
Boyle.R's Avatar
Thanks wantboost.
How about Bisimoto SS valves?
http://bisimoto.com/store/index.php?...roducts_id=197
Old Jun 12, 2013 | 03:19 AM
wantboost's Avatar
Who is Mr Robot?
Eh. I've always preferred ferrea
You also need to check the valve guides because of the bent valves somehow touched the valve guide it will be damaged or off center or out of round. This will cause excess play in the valve at the seat and cause even further problems
VTECcnIT
Nov 9, 2005 05:43 AM
BigPlansNoMoney
Nov 2, 2004 06:45 PM
StinkyTofu
Aug 15, 2003 11:36 AM
Riptide101
Apr 1, 2003 08:43 AM
sneakychaos
Sep 9, 2002 05:48 PM
