92 civic front end squeaks in steering/suspension
Old Jun 11, 2013 | 11:20 AM
wheelerboy12's Avatar
Default 92 civic front end squeaks in steering/suspension
i have a 92 civic LX bone stock, with the d15b7 motor, and it has some squeaks up front, the car has had them since I got it about a week ago, for a while I though they were in the suspension because it would squeak whenever I got in or out, and when driving, but it squeaks when i turn the wheel while sitting so i believe it is also in the steering or it is all in the steering, but I have no clue where to look, any help would be awesome, thanks.
The PO of the car said he replaced the lower control arm bushings but it did not fix the squeak.
Old Jun 11, 2013 | 01:15 PM
sleepyaccord96's Avatar
Default Re: 92 civic front end squeaks in steering/suspension
how many miles are on the car?
Have you inspected it to see if anything looks new and has been replaced
inner tie rod ends
outer tie rod ends
sway bar END links
sway bar frame bushings
upper ball joints
lower ball joints
control arm bushings (UPPER AND LOWER)
Compliance bushings LEFT AND RIGHT
^^ all of the above need to be inspected for excessive wear/breakage/tearing.
steering rack bushings as well.
Old Jun 11, 2013 | 03:33 PM
278,xxx miles, all 100% stock
and no i havent checked anything, i havent had time lately, i was going to do it today but i woke up and it was raining so that put a stop to that.
thanks for the reply, Love your h22 hatch by the way.
Old Jun 11, 2013 | 09:07 PM
fragmare's Avatar
Could be any of numerous components of the steering/suspension. Have a buddy get in the car while turning the wheel while you kneel down and listen to where it's coming from.
Old Jun 12, 2013 | 01:57 PM
Chris Westlund's Avatar
Extremely likely to be your lower ball joints. They bear the full weight of the front of the car and have the task of rotating when you steer, Very typical to be making noise at 200k+
Old Jun 15, 2013 | 12:58 PM
Think I found the squeak, but I'm not sure what that is, or how to replace it, any info? I've never done anything with steering or suspension on a Honda so I have no clue what any of it is other then the upper and lower ball joints and control arms, don't know much about rack and pinion steering since all my vehicles before this have been solid axle 4x4's and a 90' prelude that I only had for a month and never actually drove since I never got it registered.
Thanks.
Edit: Forgot to include picture lol
codizz88
Jul 10, 2016 05:48 AM
Senorsquez23
Feb 1, 2015 01:12 AM
