D16z6 Squealing noise coming from crank pulley area
Old Jun 9, 2013 | 06:50 PM
marylandeg's Avatar
Default D16z6 Squealing noise coming from crank pulley area
Car: 94 Honda Civic DX auto
Engine: d16z6
I'm having some squealing noise coming from the crank pulley area.
I removed the belts from the alternator, power steering pump and AC compressor To eliminate any of those as the cause of the problem. I did a little research and I'm going to check the keyway and the crank bolt tomorrow. I was just wondering If anyone had any other ideas to look for or had a similar problem.
Short clip of the sound
Old Jun 9, 2013 | 06:55 PM
Wdpfreak145's Avatar
Default Re: D16z6 Squealing noise coming from crank pulley area
Definitely get that crank pulley off of there and check it out. Another answer might be to remove the upper timing cover and check to see if its something within the timing system.
Old Jun 9, 2013 | 07:04 PM
B_Swapped93's Avatar
did you do the timing belt or anything related recently ?
Old Jun 9, 2013 | 07:23 PM
marylandeg's Avatar
Thanks I'll definitely check out the timing belt.
I did not change the timing belt. I owned the car the engine came out of, It ran fine when I removed it. It sat for about a year before I did the swap.
Old Jun 9, 2013 | 10:37 PM
.Gen2gsr.'s Avatar
Bad tensioner or water pump pulley
Old Jun 10, 2013 | 08:52 AM
Psychoteen101's Avatar
sounds like the tensioner pulley is possibly bad. maybe the water pump.
Old Jun 23, 2013 | 11:32 AM
marylandeg's Avatar
I changed the timing belt, the tensioner, and the water pump. But the engine is still making the same noise as before. The water pump and tensioner that I changed out seem to be fine they both spun freely without binding.
I know that this engine ran fine before when it was in a crx but the only difference was that it had a manual trans attached. Do you think this noise could be caused by something in the automatic trans?
PR8urVtec
Aug 24, 2010 11:24 AM
longlivekel1
19
Apr 6, 2010 05:59 PM
eM1<3
May 18, 2009 12:56 PM
accrdwgnguy
Mar 5, 2009 01:21 PM
worditsmenick
Aug 31, 2005 01:43 PM
