Broke bolt rear right
Old Jun 9, 2013 | 03:48 PM
deerman2701's Avatar
Default Broke bolt rear right
So I was cranking on this bolt and it broke on me. That sucker is in there tight.
Any suggestions how to get it out?
Old Jun 9, 2013 | 03:49 PM
Default Re: Broke bolt rear right
Here's the pic
Old Jun 9, 2013 | 03:51 PM
grumblemarc's Avatar
The Grumpiest
Sawzall.
Old Jun 9, 2013 | 04:00 PM
B_Swapped93's Avatar
angle grinder and a torch to burn the bushing out(makes it a bit easier).
Old Jun 9, 2013 | 04:33 PM
n/a2boost's Avatar
Old Jun 9, 2013 | 04:34 PM
What am I cutting???
How will cutting get the bolt out. It's threaded in the assembly isn't it?
The bolt moves a little up and down but that's it. So frustrating.
Old Jun 9, 2013 | 04:43 PM
n/a2boost's Avatar
I cut the metal part of the bushing with a sawzall,so once the arm is removed I could put vise grips on the inside to get the rest of the bolt out. It's a big pita.
Old Jun 9, 2013 | 04:44 PM
jbpnoman's Avatar
You're cutting on both sides of the toe arm so it can fall out freely. Then you use the torch to burn out the gasket.
Old Jun 9, 2013 | 09:13 PM
Gonna try to cut it tomorrow.. also what is the actual part called? I want to get a replacement tomorrow but cant figure out the actual name on advance auto website
Old Jun 9, 2013 | 09:48 PM
I can only find aftermarket adjustable ones on ebay... I cant find OEM ones anywhere..
Old Jun 9, 2013 | 09:54 PM
n/a2boost's Avatar
I googled it and this is what I found. I'm not sure what is cheaper,replacing the whole arm or just replacing the bushing.
http://www.am-autoparts.com/Honda/Ci...Fcad4AodmmAAGw
Old Jun 9, 2013 | 10:07 PM
POPLERO's Avatar
that sucks.. keep us posted on how u get it off. fingers crossed*
Old Jun 9, 2013 | 10:45 PM
Honda dealer pick n pull local ads(car part out). a bushing is cheaper then the arm but why that is being considered is beyond me.
Old Jun 9, 2013 | 10:58 PM
n/a2boost's Avatar
Why would the bushing being considered be beyond you? Theres nothing wrong with the arm itself and with a new bushing its good as new. It comes downs to what's advalable,fastest and cheapest way for the op.
Old Jun 9, 2013 | 11:22 PM
a new arm would be x2 what a bushing would be there's a line when it comes to cost/practicality vs availability. maybe you misunderstood what I meant bushing>cheaper than whole new arm
Old Jun 9, 2013 | 11:28 PM
n/a2boost's Avatar
I did misunderstood what your saying. It sound like you where saying a new bushing was a bad thing. Just trying to give op other option.
Old Jun 10, 2013 | 02:35 AM
fragmare's Avatar
Bushings, by themselves are crazy cheap. If you don't have access to a shop press, they're kind of a pain to press in, but otherwise really inexpensive.
Old Jun 10, 2013 | 06:46 AM
Can I get the Bolt from like Home Depot? Anyone know the specs on that bolt?
Old Jun 10, 2013 | 10:02 AM
Is it this bolt I need?
http://www.hondapartsunlimited.com/o.../90172-s04-003
Number #18
I want to go to Home Depot to get a bolt but no idea what the thread pitch is
Old Jun 10, 2013 | 10:03 AM
yes #18 is the correct one
Old Jun 10, 2013 | 10:36 AM
Damn it 2 bucks for the bolts but 15 for shipping... wtf haha i wonder if my local honda shop will carry them even thoughthe car is so old.?
Old Jun 10, 2013 | 10:39 AM
Fnix's Avatar
You may have to cut the welded part off as well since it is threaded in there and may be rusted. Use a lockwasher with a nut. I had to do the same on my trailing arm.
Old Jun 10, 2013 | 11:49 AM
Well I cut the arm off and just have the threaded part left and its seized in there pretty good. Now what. I can't even move the car anymore now !
Old Jun 10, 2013 | 02:07 PM
they will, you may have to wait a day or so. at least that's how it is for parts for my 94 GS-R
Old Jun 10, 2013 | 02:50 PM
Got the bolt from honda. And got the old one out. I had to cut out the threads. But I bought a nut. Lock washer and loctite. Should be okay
thekidsnitty
Suspension & Brakes
Jul 2, 2012 05:57 PM
OneDirection
Suspension & Brakes
13
Jan 17, 2005 07:19 AM
B18G
Jan 6, 2004 08:48 PM
logictron2000
15
Apr 24, 2003 08:59 AM
Matt B
Apr 20, 2003 07:12 PM
