1990 Accord hitting 200k. what should I look out for?
Old Jun 9, 2013 | 09:35 AM
mwso's Avatar
Default 1990 Accord hitting 200k. what should I look out for?
It's a two door 2.2 liter automatic LX and I love this car to death. Since it will be hitting 200,000 miles on the odometer, I want to know what I should check or replace to keep this thing on the road another 200k. I all ready planned a tune up, but I want to know if there's something I might overlook that could be a disaster waiting to happen. Basically, any wisdom is welcome. Thanks.
Old Jun 9, 2013 | 09:57 AM
GhostAccord's Avatar
Default Re: 1990 Accord hitting 200k. what should I look out for?
Timing belt, balance shaft belt and tensioners, water pump and valve adjustment would be something to look at if you have not done this maintenance recently. Along with your regular tuneup and maintenance.
Old Jun 9, 2013 | 12:42 PM
MAD_MIKE's Avatar
MM Gruppe B
Front wheel bearings, lower balljoints, front sway bar endlink bushings, will eliminate front end noise, add smoothness to the steering, and reduce body roll, returning the front end to a more like new condition. Timken(NTN) wheel bearings can be purchased through RockAuto for ~$30(US) Discount code -152440456776233[Good until 28 July 2013.]
Old Jun 9, 2013 | 12:46 PM
grumblemarc's Avatar
The Grumpiest
All maintenance items first, then everything else.
xemi
Oct 17, 2018 08:03 AM
market525
Jan 13, 2011 06:50 PM
lt1tyrell
Sep 9, 2010 10:15 PM
jwagner
May 3, 2006 02:10 AM
