Electric ground locations in engine bay
Old Jun 8, 2013 | 07:47 AM
motor motor's Avatar
Icon6 Electric ground locations in engine bay
Just bought a 91 Accord EX for the wife. It runs fine but, of course, its got issues.
I want to avoid mystery electrical problems by cleaning as many connections and grounds as i can. The grounds on top of the motor are obvious, but are there grounds hidden underneath the motor I need to address?
Can't see much past all the vacuum hoses and ducts. Used to American V8's and such, so not used to this engine compartment yet.
Thanks!
Old Jun 8, 2013 | 01:21 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: Electric ground locations in engine bay
There should be a two wire three eyelet ground strap over on the left front where the front of the engine is, it will be mounted across the engine mount with the smaller gauge wire going to the cam/valve cover. Part #10 in this image.
There is a main ground cable that goes from the battery negative down to the transmission.
#12 in this image.
Old Jun 9, 2013 | 08:40 AM
Thanks for the info and diagrams Mad Mike!
Cheers!
C_R_X_V_T_E_C
May 26, 2009 12:00 PM
TravisB16a
May 16, 2008 05:27 PM
davejj40
Sep 9, 2004 11:40 AM
steve_s
Feb 21, 2003 08:59 PM
S13Koop
Aug 12, 2001 04:21 PM
