95 eg sedan build
Old Jun 6, 2013 | 11:30 PM
tony_da_tiger's Avatar
Default 95 eg sedan build
First day I got it installed skunk2 springs and tokiko blue shocks the z6 motor has 72k miles on it automatic trans
Old Jun 6, 2013 | 11:33 PM
Default Re: 95 eg sedan build
Me and a friend pulled the d15 motor out and installed the d16z6 its an automatic for now I have all the parts for the 5 speed swap had to wire up the VTEC solenoid and pressure switch a few threads on here was very helpful on how to wire it properly
Old Jun 6, 2013 | 11:36 PM
Also have the rear disc conversion almost ready to go on I need to press in the es bushings got the 4040 PV and 15/16 integra master going in also
Old Jun 6, 2013 | 11:37 PM
Had some free time to powder coat and polish the BC
Old Jun 6, 2013 | 11:40 PM
Also recently finished sanding and polishing my gsr blades they were in terrible shape got them off craigslist they were pitted and curbed pretty bad
Old Jun 6, 2013 | 11:43 PM
Added a rear poly lip and red clear tails which I sprayed with red nite shades also clear corners
Before lip
After
Old Jun 6, 2013 | 11:45 PM
Side shot
Added the fat fives
Old Jun 6, 2013 | 11:47 PM
Ek coupe side skirts done today
Old Jun 7, 2013 | 01:46 AM
CivicInUse22's Avatar
looks hella clean man. What do you plan on doing to it anyway??
Old Jun 7, 2013 | 03:48 AM
JuggerNaut-CTR's Avatar
Hey, you are in Vancouver aren't you?
Just so you know unless you are swapping to bigger front brakes, the 40/40 prop valve would be a wasted effort. And I saw you mentioned the integra 15/16 MC but didn't see you mention the booster. You are aware you will need to swap out the booster as well right?
I like what you've done so far.
Old Jun 7, 2013 | 04:05 AM
doctorake's Avatar
If you loved me, you'd all sell me your magic cards to me today
Veteran: Coast Guard
Community Builder
Looks nice, get that manual trans in there quick.
Old Jun 7, 2013 | 12:58 PM
Yeah I'm over in Vancouver
And eventually I'm going to upgrade the front breaks so i might as well install the 4040 while I'm in there and is the booster really needed I've read a few threads and they are all different opinions lol
Old Jun 7, 2013 | 12:59 PM
I'm getting the trans in asap just waiting on the conversion mount and the flywheel inspection plate either than that I'm ready to go
Old Jun 7, 2013 | 01:01 PM
Also got my JDM thin side moldings in the mail today they should be on soon might plasti dip them for some protection
Old Jun 7, 2013 | 01:13 PM
sleepyaccord96's Avatar
nice sedan!!!!
Old Jun 7, 2013 | 01:22 PM
Some parts ready to install soon
Old Jun 7, 2013 | 01:30 PM
Also have to install my gsr rear lcas and 14mm sway bar so that will be done the same time the rear disc is installed
Also I successfully got my old RTA bushings out today by throwing them in my friends fire place and a couple pieces of wood 45 min later came out clean as a whistle just have to wire wheel them down and paint then I can press in the ES RTA bushings
Old Jun 7, 2013 | 01:31 PM
The bolt pattern is different on the teg master cylinder, so you would need the booster. A 91 ex sedan has a 15/16 master and is same bolt pattern.
Old Jun 7, 2013 | 01:36 PM
OK cool thanks for the input ^^
Old Jun 7, 2013 | 03:39 PM
Picked up the integra booster
Old Jun 7, 2013 | 03:40 PM
Sneak peak interior pic lol
Old Jun 7, 2013 | 03:55 PM
Lokoryder18's Avatar
she looks nice bro good luck with your build
Old Jun 7, 2013 | 03:59 PM
grumblemarc's Avatar
The Grumpiest
You painted the hubs as well?
Old Jun 7, 2013 | 04:01 PM
Thanks I've been collecting parts for awhile
Old Jun 7, 2013 | 04:03 PM
Yeah I just masked off the important stuff and sprayed away the trailing arms was painted phantom grey pearl and the dust shield,calipers and hubs all satin black
