93 Civic CEL 'ELD Code 20'
Old Jun 5, 2013 | 09:01 PM
nates97coupe's Avatar
Default 93 Civic CEL 'ELD Code 20'
1993 rhd Civic cx
Break down on the car to get an idea; Has a high comp LsV(jdm rhd engine harness from a b16a), still has the Lhd usdm dash harness, battery is relocated to trunk. Running a virgin p28 ecu(not the greatest idea but whatever)
Ive had the car for about a month. Started up fine, drove fine every day, no CEL's, ect. One day 2 weeks ago, the car threw a CEL and the idle shot up to 1300rpm and stayed, bogged down/sputtered while driving. turned it off, did it again..and would randomly do it off and on but atleast once a drive. Well i checked my grounds, wiring ect, and i looked in the hatch at the battery and noticed the battery was swollen and leaking. Drove the car and didnt do it for 4 days straight. I took the battery out for saftey purposes and swapped it with a used one off a friend and swapped my alternator with a used one off another friend. Long story short, after driving for a few minutes it did it again..
ive tried a chipped p72, tried reseting the ECU, put a new batt/alt in, ect. all my grounds are there.
Why am i still throwing this code 20?? Ive read its the fuse box that can go bad, or too much volt/too little, a bad ground, ect..
Old Jun 5, 2013 | 09:02 PM
Default Re: 93 Civic CEL 'ELD Code 20'
can the fuse box go bad out of no where? if so whats the cause for it?
Old Jun 6, 2013 | 05:34 AM
ttt need to figure this out asap!!
Old Jun 6, 2013 | 06:38 AM
Former User's Avatar
Do the ELD service manual tests for the ELD wires that run to the alternator and ECU.
Old Jun 6, 2013 | 07:31 AM
Link? But my last alternator over charged my last battery. Could those wires cause that to happen?
Old Jun 6, 2013 | 10:20 AM
It's not hard to find your Civic's service manual on the internet. It's against site rules for me to post a link.
j.kor11x
Honda Civic (2006 - 2015)
Jan 18, 2019 07:08 AM
AudioFunk
Oct 29, 2013 05:19 PM
Si Jeff
Jan 11, 2009 10:57 AM
Si Jeff
27
Dec 20, 2005 05:34 PM
S2KILLA
Jul 28, 2005 08:26 AM
