turbo oil leak into intake piping
Old Jun 5, 2013 | 08:42 PM
Jackzor's Avatar
Default turbo oil leak into intake piping
Okay, I have a prelude with an h22a with a turbonetics turbo and wastegate. Now. When I run down the back roads out by my house (at full boost (10lbs)) a few times I start to see ALOT of white smoke from my exhaust. Also, I have oil in my intake piping. Now, I'm sure the car burns some oil by itself but I don't think there should be oil in my piping. It also blows out my blow off valve after alot of hard driving. Does this sound like an oil seal leaking in my turbo?
Old Jun 5, 2013 | 09:10 PM
TravisBiggie's Avatar
Default Re: turbo oil leak into intake piping
seal can be going out. how does your turbo oil return line look?
Old Jun 6, 2013 | 08:16 PM
Jackzor's Avatar
The return line look like crap but I think its fine. I pulled my hot side piping and the cooler has plenty of oil in it. I think I need new seals. Can anyone point me in the right direction?
Old Jun 6, 2013 | 08:51 PM
Jackzor's Avatar
There is somewhat of a kink in the return line. I should fix that?
Old Jun 6, 2013 | 08:52 PM
wantboost's Avatar
Who is Mr Robot?
Post pics of the return line and the oil
We also need more info like turbo type and size. Journal or ball bearing
A few possibilities:
Oil pressure is too high and a restrictor is needed (assuming you don't already have one)
Poor oil return (drain diameter (could be too small), fitting type and locations ((no 90* fittings off the turbo or anywhere else))
return line routing ((no kinks, needs to be straight and slope downwards or vertical (preferred))
Location of oil return fitting on oil pan, could be too low or high, or not in the proper location
And worse case is the compressor seal has failed, meaning it's time for a rebuild
Old Jun 6, 2013 | 09:39 PM
Jackzor's Avatar
Here are some pictures of whats going on. Thanks for the input.
Old Jun 7, 2013 | 12:46 AM
KevinEF7's Avatar
Your oil drain is fine. How much axial shaft play on the turbine?
Most likely needs rebuilt, and is blown
Old Jun 8, 2013 | 07:32 PM
Jackzor's Avatar
I cant move it in and out but I can move it up and down some.
Old Jun 10, 2013 | 10:54 AM
wantboost's Avatar
Who is Mr Robot?
Does it touch the housings?
A seal can fail and the turbo won't have excessive shaft play because the bearing system isn't damaged.
Old Jun 10, 2013 | 11:28 AM
TheShodan's Avatar
Moderator
Umm no.. his cartridge is angled almost 30* towards the front of the car. That's why he's having problems. The oil under pressure is backing up into the cartridge itself where its being pressed past the thrust bearing into the compressor side of the turbo. The op thinks he can make a "straight shot" to the oil pan by rotating the cartridge itself so that the drain points down towards the pan. His oil feed flange is basically FACING the intercooler compressor pipe . (3rd picture).
He must readjust his cartridge to be completely vertical, and use a better stainless line AWAY from that heated downpipe. He also need to check oil pressure at cold start/WOT to see whether or not a properly sized restrictor is needed for the Turbonetics.
Many turbonetics have oil sealing ring issues, but that's at the REAR of the turbocharger. Not as much in the front thrust bearing. this is an installation error, from the look at things here.
If he does not, he'll continue to have problems despite a "rebuild."
So, change parts, reconfigure, check oil pressure, then see if a rebuild is needed.
Old Jun 10, 2013 | 01:57 PM
KevinEF7's Avatar
The third picture to me does not show a 30* angle, I didnt think the angle pictured would cause damage or pose a threat, I thought it had to be quite slanted to the side to not drain proper and backup
Old Jun 10, 2013 | 10:34 PM
TheShodan's Avatar
Moderator
Yep. you have to invert the picture. But yes, its a VERY heavy angle and WILL affect its performance and use, including oil backups to cause the very issue he's experiencing.
Old Jun 12, 2013 | 10:43 AM
BigMike0147's Avatar
Need better pictures to show the angle of the center cartridge. It's hard to tell with those at the angle. Get some shots from standing in front of the engine bay looking down/forward. That way people can see the angle in which the oil feed port is.....
Old Jun 17, 2013 | 12:41 AM
Jackzor's Avatar
I'll try to get some in the morning. Are you saying it might not need a rebuild?
akcapr
Mar 14, 2011 12:24 PM
boostedSI90hatch
May 16, 2007 12:26 AM
Blkteg97
Nov 16, 2004 08:04 AM
khmboostedeh2
Sep 4, 2004 07:45 PM
Lenthrax
Jan 31, 2003 10:00 PM
