90 crx si swap b18a1
Hey there I just got done swapping a 90 ls into my 90 crx si and now it go to gear put wont lock? Does this mean I need a new clutch? When I put it in 1st gear I can still push the car. I need help because this is my dd.
Even a clutch worn past the service limit will grab a little, enough to hear grinding sounds if you push it while in 1st gear. Check to see the shifter IS putting it into gear, and as mentioned, make sure both axles are in 100%. If one isn't in all the way and you have a non-LSD trans, the diff will spin and not get "locked" by the motor&clutch.
oneeezy
Aug 22, 2010 06:33 PM
Pnoyej6
14
May 5, 2006 09:29 PM
b20vtecv8killer
Aug 2, 2004 08:23 AM
