Rough low idle/Engine rattle video update.
Hey guys ,
In one of my first ever post I asked about rough low idle after 20-30 seconds of start up. IACV was cleaned,TB was cleaned,vacuum leaks were checked for,(Car died when I covered the TB),No CEL. This video shows what I;m taking about and also you can probably the intake is sucking in air in abundance at the same time.
http://www.youtube.com/watch?v=Uv5p0...ature=youtu.be
I also ask about rattling under valve cover close to cylinder one. Video link:
http://www.youtube.com/watch?v=nSh84...ature=youtu.be
What are your inputs?
I sprayed carb cleaner on all the intake area hoses. Idle never rose or changed. After taking off the intake and cover the throttle body hole,the engine died.
check coolant level and check spark plugs for any white residue on them. might have coolant leaking from the head gasket..once its all burnt up it will run normal
Coolant level is okay. I just check the plugs and there's no white substance. Are the plugs suppose to be tight? Plug 2 from the left felt a bit loose.
hondafrk
Oct 1, 2002 04:03 AM
